Drying time for oil?
Ken Richardson
>I've put two coats of tung oil on, 24 hrs apart. 3rd day-sanded with 600 grit w/d paper with light oil. Piece feels dry, looks dry, is it dry? How do you tell? Thanks for the help.
Ken Richardson
Ken Richardson
Ken Richardson
testing
Bill Tindall, E.TN
>Most people rub excess oil from the wood after application and the resulting wood appears "dry" whether it is or not. To know for sure put a thin film of the oil on something nonporous like glass and then you can tell for sure whether after XX days it is dry or not.
Re: Drying time for oil?
Howard Acheson
>The test is how it smells. If you detect an odor, it's is still curing.
That said, are you referring to real, 100%, pure tung oil or on of the faux "Tung Oil Finishes?". The answer to your question will be different for these two different finishes.
What Howard said
Rob Sandow
>If you applied pure tung oil, it is doubtful it cured sufficiently in the time you mentioned. If you applied something like 'Formby's tung oil finish", then it's fine and most definitely dry enough. This stuff is really just a thinned varnish that's good for wiping on and is very clear with almost no color, which is why they call it a "tung oil finish"
Rob
Dry vs. Cured
>Ken,
Don't forget that oil finishes go through 2 stages in reaching their final cured state.
Stage 1 is out-gassing of the solvent thinner; this can take several hours to days depending on the solvent and the conditions.
Stage 2 involves the actual curing of the oil film through the chemical reaction we call polymerization where oxygen is drawn from the air into the finish's film where it reacts with the oil and resin molecules. (It's this chemical reaction that creates the heat that causes improperly stored oily rags to catch fire) This process can take several weeks or more to complete depending on the oil, and during this time the film gets harder, tougher, and thinner. A oil finish that started out as 8 mils thick after most of the solvent evaporated ("dry to the touch"), may shrink down to less than 5 mils, depending on the formula's total percentage of solids. If you've ever put a glass smooth oil finish on an open-pored wood like walnut or oak only to see slight grain pores show up a month or two later, you've seen a prime example of the process.
Point here is to distinguish between an oil finish that is merely dry from one that is actually "finished."
mm
Please check your terminology
Michael Dresdner
>Mark's explanation is excellent and quite comprehensive. Nicely done. My only plea is to please avoid the terms off gassing and out gassing.
"Stage 1 is out-gassing of the solvent thinner"
Those terms have a very specific meaning in coatings chemistry, and it is not the one being used here. It refers specifically to a gas formed as the byproduct of a chemical reaction taking place within the coating, not as the evaporation of an included volatile.
For the sake of clarity, please use the term solvent evaporation.
Thanks.
Checked
>And properly corrected!! Thanks Michael.
My error comes from non-finishing areas like "degassing" mixed resins and viewing vapors as gasses (like water vapor) even though it may be a misnomer in any given situation.
I was actually told (by whom I don't remember) that once a film develops a skin but the coating continues to lose solvent that such is "out-gassing" of the solvent because it must penetrate through the skin as a gas. I never questioned this, although I can understand that as the solvent migrates from the bottom of the layer to the outside surface that it keeps the film at least partially dissolved until all the solvent has evaporated.
I'm not, however, married to the term, which at my age always raises digestive issues.
mm
