I'm going to put together a couple of table saw extension tables this weekend. The top will be 3/4 ply probably two layers with a 1/4" hardboard on top. Am I OK with using construction adhesive to bond the hardboard to the ply? Or is there a prefered method?
>Mike, will this be the tempered variety or regular? Either way, I wonder why you want to adhere the hardboard to the plywood. The day may come when you want or need to replace the hardboard - then what? I think I'd prefer putting a hardwood border around the plywood, leaving it 1/4-inch above the top surface of the plywood. Then just place the hardboard down into that and it should stay put. If the top surface ever gets messed up, just lift it up and flip it over for a fresh surface.
If you still want to stick it down for some reason, double sided carpet tape placed in a few spots will do quite nicely.
Excellent point and suggestion. I was planning to edge border it with hardwood. I know I've seen/read that design before. I'll try it without the carpet tape first and go to it if I think I need to.
