Hide Glue and The Creeps
Joe Burke
>I don't know if this is creep or not. I'll describe it and see what the consensus is.
Last year around Christmas I built a jewelry box and used Franklin Liquid Hide Gule for almost all the assembly. One reason I've been using the stuff is because I'd been under the impression hide glue didn't creep.
After finishing the box ... days not hours ... I noticed what could only be glue working it's way back out along some joint lines. At the edge of some spline mitres ... corners of the box ... and along some other joints where I'd glued parts together. The once very sharp and clean corners on the mitres now feel rough and it's got to be glue. It's as if the glue worked it's way back out of the joint and hardened off. It can't be anything else.
So what gives? I've reread my info and hide glue is listed as a good option against creep, and there was no bad mouthing of the liquid stuff.
Is this creep or something else, and why might it have happened?
I used the same hide glue in the last couple of days to inlay some 1/16th inch rosewood stringing and after scraping and sanding it flush I can now feel a bit of the same thing along that line.
Set me straight before I move to urea formaldahyde powder. I know that won't creep.
