Timesaver belt cleaning
Dave Winters
>Isn't there a crepe rubber sanding belt cleaner for a Timesaver? Seems like someone makes one but I can't remember where I have seen it...
Thanks!
Dave
Dave Winters
Thanks!
Dave
Just the block ? . . .
steve mackay
>Got mine at Sears. And it really, really works.
Re: Just the block ? . . .
Dave Winters
>Looking for something you actually feed through the machine...
Re: Timesaver belt cleaning
Thomas S Stockton
>I think Grizzly carries something like that
Tom
Re: Berlts are typically washed...
Rick L
>Standard way is to clean the belt with special cleaners. Mineral spirits work as well.
Your link didn't show anything special. Might have seen something like a big crepe block advertised years ago but don't see the practicality of such a thing.
Re: Found it...
Dave Winters
>Look under sanding accesories, then belt cleaning sticks.
>I have been clearing the sand paper for myPerformax with Simple Green. I gust mix some in water in a gallon jug and drop the rolls in for an hour or more. Then brush them off with a nylon or brass brush and flush them off. I have done 4 X 24 belt sander belts also.
I would try to make a cylinder that would accept the Belt out of the Time Saver and pour in a gallon or two of Simple Green and fill it with water. To avoid have to use too many gallons of Simple Green, keep the container as small as possible. I would try it on one belt first to be sure it does not release the seam.
Let me know if you try it. I have a friend with a Timesaver and if it works for you I will help him with his. If we beat you to it, I will let you know.
Re: Trying again
Kneale Brownson in sunny N. MI
>TRY THIS
Here? *LINK*
Dan Donaldson
cleaning block
