Installing a MastRlift Router Plate *Many Pics
Garrett in Victoria
>The weekend before last the annual Wood Show came back to Victoria. Alas, the disappointing trend of previous years continued, and the list of exhibitors was smaller again. Nevertheless, some bargains were to be had for the discerning eye, and a JessEm MastRlift for $189 proved irresistible. (I suspect it was a display model, because it was in an opened box, but the small parts packaging was intact, and contained the hand crank and a small plastic bag with an Allen wrench, the insert, the insert wrench, and a post for the insert.
JessEm offers this lift in two plate sizes - 9 - 1/4" x 11 - 3/4" or 8-1/4" x 11-3/4" � both CNC machined from a 1� thick chunk of aluminum. The smaller size drops into a standard opening. My bargain was the larger one that fits the JessEm table, so I had to replace the existing top.
No problem. I had a couple of re-cycled 1� thick panels with laminate on both faces, and one of them required only a single saw cut to become the new top.
With the top in place and the Lift positioned upside down, I drew its outline. A circle template showed the corner radii were 1 3/8� so I took one of the new carbide Forstner bits I had also purchased at the show, and using a straight edge and a square, tapped it to punch four locator holes.
I then drilled the holes to a depth of 3/8�, the thickness of the rabetted edge.
Next step was to cut some scraps to frame the outline of the plate as templates in order to rout the 3/8� rabbet using a top-bearing �� pattern bit and then cut out the hole with a �� solid carbide bit.
When I dropped the plate in the opening, the edge fit was good, but a straight edge and feeler gauge showed it was sitting .02� high. Not bad for the first pass, but not good enough.
Since this is a top of the line product, JessEm includes a couple of useful features. I didn�t need the edge clamps that would have been necessary had the side-to-side fit been loose, but the leveling feature came in very handy. As the photo below shows, each edge has a pair of inset strips with a hex head slug in each of the corners. Screwing the slug in raises the strip, and, therefore, the plate.
(When I removed the compartment that housed the router, it would have been intelligent to have also emptied the lower cabinet before routing the cut-out!) In any event, I drilled 4 �� holes in the table�s corners to match the locations of the slugs, and then made another pass with the pattern bit to remove just a hair more than the .02. An Allen key stuck through the holes quickly achieved a perfectly flat fit.
With the plate now in place, I marked, routed, and installed the two pieces of aluminum tee that manage my shop-made fence.
The MastRlift is designed specifically for the big Porter Cable 7518/7519 routers, but JessEm sells an adapter package for the Milwaukee 5625, as well as a very slick adaptor for smaller cylindrical routers including the PC 690, Bosch, etc. I�ve been happily using a Makita 3612C in my table for the past 8 or 9 years, but there�s no way it can be adapted to this lift, so I�ll be buying a 7518 �the �bargain� gets expensive! � during a trip to Washington in a couple of weeks. (Although the Canadian dollar is now worth just over US$1.03 - what a change! - Canadian retail prices don�t yet reflect that new reality, and the difference for the router is $150 or more.) In the meantime, I�ve reassembled the Makita to use as a hand-held, and dedicated my 690 to the table.
The insert � on the left in the photo above - is a remarkably inexpensive (<$30) piece of beautifully machined that drops into the Lift. The motor slips snugly into it.
The JessEm manual suggests raising the lift until its O-rings touch the underside of the plate, and then inverting it on a couple of wood blocks to install the router. A 5/16� Allen wrench loosens and re-tightens the clamp.
With the lift, adapter, and motor in the table, above-the-table bit changes are easier than in any other configuration, even with the motor out of the base on its own. That�s because the Lift enables you to position the narrow lower nut � you know, the one the wrench always slips off � so that you can hold its wrench flat on the table while using the other to loosen or tighten the collet . (If that�s not easy enough, Porter Cable offers a collet that uses a single Allen key for bit-changing, but it doesn�t have the auto-bit-release function of the wrench collets.)
In use, the MastRlift�s �direct drive� is smooth and precise. There is no belt to stretch � or break � and no backlash (slop) between the �� threaded rod and its �nut�. There is also an adjustable tensioning screw to ensure that no vertical slippage can occur. Each full rotation of the crank raises or lowers the bit exactly ��. The indicator on the table is marked in increments of 1/64�. If I have a single gripe, it�s that the indicator cannot be re-set to zero for any desired position, but it�s not a big deal. A pencil mark on the table does the job.
A happy purchase.
Cheers, Garrett
