Plans for a shop air cleaner?
Roy Anderson
>I have a small shop in the basement, and I need to crib together an air cleaner. I'm too cheap to buy one of the store-bought kind. I just want a box with a fan and a filter to hang up in my shop.
Does anyone have any plans for this?
Thanks in advance.
Re: Plans for a shop air cleaner?
Ron Jones
>Just get a box fan ~ $20 and a quality furnace filter ~ $15 of approximately the same size. Attach the filter to the fan on the intake side. Maybe seal the filter/fan edge so that all air flow must be filtered. Turn it on and you are in business. Not fancy, not pretty, but works fairly well.
John Veerkamp
>Look in shop shots, link on the left side. There is at least one there.
John
Tom MacGregor
>I made a plywood box with slots for two filters. The outside filter is a cheap 2"x20"x20" fiberglass furnace filter, and behind that is a 2"x20"x20" pleated filter that traps finer particles. The cheap filter makes the better one last longer. Airflow is provided by a shop-vac motor pulled out of the metal bin at the recycling center, although many other types of blowers could be adapted. It hangs from the ceiling joists with a switch on the wall and makes a lot less noise than you'd expect. It does a very good job of filtering out the fine airborne stuff missed by the dust collector ports at the machines.
Shaver built his
Lee Schierer - McKean, PA
>Maybe Jim Shaver can help. He built the one for his shop if my memory serves me.
Lee
Shaver's tour page says...
Charles Wiggins
>that he built his from a Woodsmith plan, but I can't find it one their plans site.
Joist Space Air Cleaner
Al Goldstein
>The best ideal I've heard for a shop built air cleaner is to make use of a ceiling joist space. Mount a fan at one end of the joist space and a filter on the other end. Then seal the ends and cover the joist space with scrap plywood so that the fan sucks air through the filter from one end of the shop to the other. Then you will have a good circulation of air throughout your shop. The trouble with most shop air cleaners is that they don't circulate air throughout the entire shop.
My $0.02
Al
>I made one out of an old furnace blower. A plywood top and bottom and four verticals a the corners. Home made tracks on all four sides hold furnace filters. The blower sucks aid in through three of them and blows it out through the other one. You could make the fourth on finer or higher quality than the others to get he double filtering effect.
You can get a blower from an HVAC contractor for nothing or nearly nothing. (I just got two more for free.) I also just learned that a lot of them are 220 motors. (out of heat pumps) Try to get 120 ones from gas furnaces. Get the blower first. figure out how big the top and bottom need to be and then what the filters will need to be. Then go to the Borg or filter store and figure out what size filters will work best. Build it to fit easily attainable standard filters.
I have mixed feelings about Ambient Air Cleaners. It would be better to capture the dust where it is created and never let it float around in the air. Air cleaners stir the air and keep the particles flying long enough to capture them. That means the particles are in the air for you to inhale. Read Bill Pents site for more than you ever wanted to know about this.
My next project is a down draft table so that I can sand and have the dust drawn straight done into the table and trapped in filters. I'm trying to figure out how to make it multi-purpose because I have he small shop blues also. It will be the extension of my RAS and may be an assembly table also. Down draft tables can be left running and make pretty good Air cleaners even if you are not sanding on them at the moment.
I am thinking that I might need two air cleaners. In opposite corners of the shop. One blowing south and the other blowing north to keep the air running in a circle. I am not fully convinced about the flying particles and breathing them. I can tell you that my cleaner catches a huge amount of dust. Probably not good, but I drop the filters out and blow them out occasionally, Outdoors. Have been using the same filters for a year. I guess if you used the box fan idea you could put it outdoors once in a while and run it backwards.
Probably a dumb question...
Dan Mitchell
>I'm very interested in making one, but how do you keep it from creating an annoying draft, especially with a strong blower & in a small shop?
Re: Probably a dumb question...
Bill Howatt
>That's what tells you it's working. :)
I made mine and had it blow into the cavity made by 2 joists. I closed off the joists until I got near a wall out of the way and had an opening there.
I have filters on 3 sides and the bottom with exhaust at top into cavity. In each side, outer filter is cheapie fiber-glass, middle is a $5 pleated material and inner is a Filtrete 2150(or something like that). I spray the outer fiber-glass one with cooking oil to aid its "catching" ability.
Bill
>That's part of it. It MUST create a strong draft. The mechanical energy of the air movement keeps the particles flying until they hit the filters. Without significant air movement they would not work well at all. In fact, one way to tell when it is time to clean the filters and thus increase the airflow it to put ribbons on the outlet side. When the ribbons stop fluttering in the breeze it's time to clean it.
But that's the criticism also. The breeze can be annoying and keeping the particles airborne give you a chance to inhale them. The ones that fall out of the air and settle onto everything else you own are not a health risk, even if they are unsightly.
The advantage of the down draft table is that they never get airborne. They just get sucked into the filter without passing your nose.
Shaver says...
Jim Shaver - Oakville, Ontario
>I built it quiet awhile ago from a Woodsmith plan, I can't remember what issue it was, but I built it 7 years ago or so....
It's all 3/4" ply and weighs a ton, but works really well.
Take care,
Jim
