Cutting and install a piano hinge
Craig
>Hello all,
I am building a window seat for my daughter. The top, a glue-up of 5/4" boards, is 21" wide by 66" long. I want the top to open so I will cut it so there is a fixed part 3" x 66" and the movable part 18" x 66". I have purchased a 72" long brass piano hinge. I will need to cut the hinge to fit. I was planning on using blue painting tape to tape the area I will cut and use a hack saw to cut the hinge at the end of a knuckle. Any other ideas/tips on cutting the hinge?
Then installing the hinge, I was planning on a mortise to make the hinge flush with both edges of the top (fixed part and the movable part). Do I also route a rounded grove (half in each part of the top) so the barrel is embedded/flush with the top of the top.
Any experiences/ideas would be appreciated.
Thanks!
Re: Cutting and install a piano hinge
David Yoho
>Craig, you should be fine cutting with a hack saw. I've done it several times before without a problem. As for the question of leaving the knuckle on top or embedding it, it's really a matter of personal preference. Do what you think is best for you. Personally, I've done them both ways and don't really have a preference.
David
Kneale Brownson in sunny N. MI
>After hacksawing, you'll be left with some sharp metal corners and edges. I always go over them with a fine file and maybe some emery cloth to take the cutting curse out of the edges.
If I were doing your installation, I'd attach the hinge to the edges of the top and fixed boards. If the seat is to be cushioned, I'd leave the center proud of the surfaces. If not, I'd notch the wood to bury the center.
Dale Lenz
Dale Lenz
>I have always had a supply of non brass screws (same size screws) on hand to test fit the hinge. The brass screws that comes with the PH are very soft and will be damaged, at least by me, after a few instillations.
