>I need a small run for my drill press and my belt/disk sander from the HF dust collector.
Since the ports are so small on those machines, my plan is to just run either 5" or 4" hvac down the wall, take a 90 and connect into the two machines.
Where or which type of adapter do I need to drop from the hvac to standard 2.5" dust ports with a small piece of flex hose?
>I bought several at Woodcraft. They had a pretty good selection.
This part was a head scratcher for me. I'm Cheap and would rather make this stuff than buy it. I found that these systems had a bunch of slightly odd fittings. The hose didn't fit four inch pipe and the blast gates weren't the same size as anything else. Spent a lot of time just fiddling with adapters.
The slightly flared hose end fittings for four inch hose slip nicely INSIDE four inch PVC fittings. They are actually intended to fit outside one the manufactured adapters, but they just happen to fit inside the PVC fittings. I found good places to use the bell ends that came onthe four inch PVC. They are slight reducers and wroked great in some places. And then there was trying to transition from metal ducts to plastic pipe and so on.
I have a 4" to 2 1/2" reducer on my Performax. It just stays there and I hook my drop of 4" hose to it with one of the flared hose ends.
(shoudl change the hood on the Performax to a four inch port, but haven't gotten to it.)
I think they make the 4 to 2 1/2 in both male and female on the 2 1/2" end, so that might matter for you.
I bought a cheap hose kit for a little shop vac at the Borg. The wand on it has about a 1" opening and it fits snugly on the dust ports on my PC tools like the belt sander and the ROS. On the other end there is an adapter to 2 1/2" From there I use a 4 to 2 1/2. Works well, but the tiny hose reduces the air flow so much that some of the stuff falls out in the big hose, so every once in a while I "give it a breath". I disconnect he smaller hose and open the system up and let is suck enough air through to clean itself.
I used hose clamps. I cut "fingers" on the ends of PVC to allow it to be compressed a little. I filled some gaps with strips of Duct tape (not a good idea). I turned some adapters on the lathe.
>I've used Fernco neoprene adapters with hose clamps that you should be able to get at most plumbing supply sources. There are versions of these things available, for example, to step down from 4" to 2.5" and from 2.5" to 1.5", etc.
>Alan, I don't know the brand I have, but they are the "ends" for four inch hose and both came from Woodcraft. The ends sort of screw into the hoses and you camp them in place. Its just a coincidence that they are slightly smaller that PVC PIPE and will slip inside a coupling. The Sewer and Drain PVC pipe I bought had a female coupling on one end. I found the ends to be useful. I cut it off, leaving about an inch of "pipe" so it was a reducer. One of them fit perfectly on my Dewalt planer and the hose just slip right in.
