Formula for rail & stile sizes?
Bri in Mtl
>I'm going to make another buffet section like the one in the photo but with 3 doors that will be the same width as the drawers above.
Is there a way to calculate what the widths of the rails and stiles should be in proportion to the raised panel size?
Thanks in advance for any and all replies.
Re: Formula for rail & stile sizes?
hb
HB
>One option is to base the dimensions of the doors themselves based on the golden mean. Then make a scaled drawing of the overall door and draw a diagonal line from one corner of the drawing to the other. Then, any rectangle drawn within the sketch of the door that shares the same diagonal from one corner to the other will be directly proportional to the door. This smaller rectangle represents the panel. Split the dimensions of the area outside the panel area and you'll have the dimensions for the rails and stiles.
Just a thought.
Good Luck.
HB
