Question about using new dust collector *LINK*
Dan Mitchell
>I just received & assembled a Penn State DC2000B dust collector with 1 micron bag filter (link below). The manual, which covers both the bag & filter cartridge examples, is a bit confusing, at least for me, as I've never used one of these before. This is compounded by the fact that the manual was missing from the (heavily damaged thanks UPS) box, and I had to have Penn fax a copy, so the images I'm using are very poor. One step in the assembly shows a plastic bag being attached to the lower half. I was assuming this was for the filter version, again, the text isn't clear, until I powered the unit up (no connections, just with 6" the inlet open) and only the LOWER bag inflated. I'm wondering if the lower bag is supposed to be lined, and is only there to support a plastic bag, and is therefore much more porous than the top, 1 micron bag, resulting in all the air escaping out through this lower bag so there's insufficient pressure to inflate the top. Do these units usually (or EVER) have plastic lower bag liners? Shouldn't BOTH BAGS get nice and fat, like I see in all the pictures of these units?!?
TIA
Dan
http://www.pennstateind.com/store/dc2000b.html
Re: Question about using new dust collector *LINK*
Firing it up again
Dan Mitchell
>I see the top bag actually DEFLATES slightly, as though there is a vacuum in that portion.
Dan
>Dan, I can't help you, but your post looked lonesome so I thought I would give it some company. I have a Delta DC with the cloth bag at the to and a plastic bag at the bottom. (not a cyclone) Both of the bags inflate and get pretty puffed up and quite firm. I used up the plastic bags that came with it and the new ones are larger. Than was an error. They expand until they jamb themselves into the frame of the DC. I have rebuilt it so that I have a 32 gallon trash can sitting under it with the plastic bag in it. The can confines the bag and prevents it from getting tangled up in the legs of the machine and makes the bag easy to roll away on a hand cart. There is about four inches of the bag exposed above the can so I can see when it is full. (Usually)
Neal in San Jose
>Dan: I'm not familiar with that particular unit, but looking at the specs shows that it should have WAY more than enough umph to inflate both bags firmly. The bottom bag should be one micron just like the top bag, and not simply a support for a plastic bag. Only two things come to mind that would cause the condition you describe. One; you mentioned that it came damaged. Is it possible the impeller is not tight on the shaft? The motor is turning, but the impeller is not? Two; is it possible the motor is turning the wrong direction? I'm not a motor expert, and I don't know if it is possible to make that one go the wrong way with incorrect wiring, but if your unit looks like the picture, the impeller should be going clock-wise when you look into the 6" opening.
Good luck
Neal
Dan Mitchell
>Thanks for the replies. The impeller is turning the correct direction & seems to have quite a bit of suction. Nothing appeared to be damaged, it's a pretty simple machine, only trouble was the manual was missing, probably fell out through the mostly open bottom. I might not have accepted it that way, but my wife signed for the package. Again though, it seems to run the way it should, other than the top bag thing. And yeah, they both appear to be 1 micron bags, or at least that they are made of the same fabric. The lower bag also has a small plastic window for viewing the fill level, which would also suggest no plastic liner, or at least a transparent one. Perhaps the top bag doesn't puff up until the lower begins to fill? Maybe I'll call them tomorrow.
Dan
>Dan, I am assuming this unit has 1100 to 1300 cfm rated capacity. With it running in free air with out a bunch of ducts attached it should be moving at least close to that. Even with excellent bags, I can not imagine that it does not have enough Umph to inflate them both. One exception is that they count on a certain amount of "cake" inside the bags and may even take that into account on the micron ratings. It would take an astronomical number of 1 micron holes to pass 1200 cfm with out generating enough back pressure to fully inflate the bags. Are the bags securely attached? No tears in them and firmly attached at the rim? No signifcant air leaks between the blower and the rest of the unit?
Dan Mitchell
>Barry-Thanks for the reply. Everything seems to be as it should be, again, a pretty simple device. No unusual noises, leaks, etc. It's rated at 1500 CFM. There's a lot of suction at the inlet, but I've never used one of these before. Is it the full amount? Who knows? The upper bag actually DEFLATES a bit when you turn it on. If you push the lower bag upward, decreasing its size, then the upper bag inflates. I'm going to call them now.
Dan
>It's hard to imagine that 1500 CFM won't inflate both bags to the max, even if part of it is overstated or imaginary. I do think that once you put some dust into it and get eh bags coated, they will surly inflate fully, unless you really do have a problem. I guess it's conceivable your impeller has a problem, but if it looks "regular" and is not missing blades and is firmly attached, It should be OK. What did they tell you?
Dan Mitchell
>He basically said it's normal, and commented rather condescendingly that they both will pump up "like the Delta commercial" once some dust gets in there. He stressed that the overall area of both bags is on the order of 30 sq', which I guess makes some sense. The motor's huge, and it really does seem to draw quite powerfully. The 1st time I fired it up w/just the 6" opening, I put my hand down there to feel the suction. I was surprised by the strength & damn near got my hand drawn into the steel impeller, which would have been an especially nasty injury. Wish I had one of those laser tachometers to measure the RPM.
Anyway, I'll hook it up (got to get some ductwork & add another 220 outlet) and see how it performs.
Thanks again for the replies.
Dan
Dan Mitchell
>Apparently the guy was right about the top bag inflating after a quantity of dust is introduced. I haven't got the collector connected to any machines yet, but as a test, I tossed about 3" of sawdust from the bottom of my shop vac cannister into the collector, and sure enough the bag started to inflate.
This thing really does suck. Wish I could figure out some way to use it to clean out the gutters without getting it full of filthy wet muck ;-)
Dan
Joseph Mulherin
>Dan, your dust collector upper bag is loaded with dust...sort of like a scab that needs to be taken off. Take the upper bag off and shake it out of the caked on dust. You people need to understand that dust collectors are NOT to be used like the ordinary chip vacuums. When use use it for collection while sawing wood on the table saws, the router tables, etc., you are picking up shavings and sawdust which will collect on the interior of the upper bags....thus not letting the air pass thru them.
If you still intend to use them like this, then take the bag off periodically and clean it out inside.
