Re: Bed leg/rail joint suggestions
Marc Evans
>I ditto something like this, but saw an interesting twist in FWW a few years ago, but can't remember which issue. Something like this if my diescription is adequate:
1) I used a square nut that was mortised into the tenon of the headboard and footboard rail tenons, before inserting them it into the post mortises. welded a big washer on in for good measure against wood-fiber compression.
2) the side rails have a slot routed for the bolt on their inside (I used a 5/16" or 3/8" if I remember correctly.
3) With a shallow mortise in the post and tenon on the rail, I slip it in and inserted the bolt which protrudes out the end of the rail into the receiving nut that has been previously buried in the post (via the FB and HB rail tenons).
This has been rock-solid for over 2 or 3 years. I have used the plates in a previous bed, but they eventually developed too much movement...
Hope the description is adequate,
Marc
