Have a question? Ask Woody!
Nesting Tables- Roy Anderson
Ron Hildreth, Alta, Iowa
>Roy,
I sent the book to you this morning containing the plans for those nesting tables. I sent them via US postal, so, unless the snail gets run over somewhere between NW Iowa and Ohio, you should see it show up in your mailbox by the end of the week.
Like I said in my e-mail reply to you, keep it if you see another project in it that you'd like to build, and return it when you're through. Word of caution- double check all the measurements within a plan. I built a bunch of mission style chairs and a table for our kitchen a few years ago, and the measurements were wrong a couple of times. Hardwood is too expensive to dive right in and not varifying accuracy!
Have fun, and post some photos here on WC when your projects are finished.
Ron in Iowa
Re: Nesting Tables- Roy Anderson
Ron-Thanks a lot
Roy Anderson
>I'll post progress reports. I'll be using the mahogany that I scored on the cheap that I talked about in a previous post.
