Tapered table legs on Jointer, new to me.
>At the WoodWorks Show I was chatting with Glen Huey. He was doing a floor demo that involved making a Demilune (half round drop leaf) Card table. Almost as an after thought he mentioned he was going to Demo how to taper table legs on a jointer, but did not have access to a jointer, so he skipped it. Said his technique was fast and easy. I asked and he explained.
Say you want a 3/8" taper 24" long. Put a line across the blank at 12 inches (half the distance) and set the jointer to 3/16" (half the amount of the taper.) Joint from the foot end of the leg to the line, straight in. Bring the leg back and tip the end down so it rests on cut end and the shoulder and joint it again. The second pass doubles the cut to the 3/8 and doubles the length to 24.
For the life of me I can't remember whether he said to make the second pass with the bottom end of the leg leading or to reverse it and cut from the 24" mark back to the bottom of the leg. We discussed it and confused each other, (or at least me), so I just tried it both ways. AS I recall, I told Glen it seemed it would work better to turn the leg around and run "down hill". His response was, "now I got to go home and try it both ways." Anyway, I just did and it worked both ways. There was a little snipe running the bottom end of the leg first, but not much. I was practicing on a pine 2x4 and the results were good, but I can't vouch for curly maple.
I knew you could make tapers on the jointer, but I did not think it was this easy, fast and repeatable. I tend to leave my jointer set at about a 1/32" and leave it alone. I think it just got a promotion.
Re: Tapered table legs on Jointer, new to me.
It works, but...
>...it's not my preferred method. (I like to use a taper jig on the tablesaw.) I do agree, though, that it is always better to plane/joint downhill on the grain. You can get away with planing against the grain on some (few) woods, but others will tear out pretty badly if you do. Another problem that crops up if you try to make that second pass foot first is that the leading edge keeps dropping as you feed the piece, and it can catch on the outfeed table.
IndyDan
>A variation on this method. Run the leg from top to bottom, but start at the point at which you want the taper to start. There may be a small amount of snipe at the beginning, which can be easily planed out.
Here you go, Barry *LINK*
David Yoho
>All your questions answered - click on the link below.
David
Tapering Legs on the Jointer
Re: Here you go, Barry
Don in Central Illinois
>That was cool. I'll have to try that. I'll cover up my lathe, so it won't know I'm doing flatwork.
Ray Binnicker
>I've tried doing it on the jointer, and, like Ellis, you have to be careful of that "drop" and it can mess up your workpiece ( as well as your pants). For some reason the tablesaw method seems to make me un-easy also.
This is how I do it:
I lay out the taper on the workpiece and mark a line from top to bottom. I then cut proud of the line on the bandsaw. I then clamp the piece in the vise or between bench dogs and hand plane to the line. It really surprised me the first time how quickly this can be done. Now, I'm not a hand tool puriest. But, I do enjoy this particular job like I described. You don't have to worry about all four legs being tapered exactly equal either. Once you get the table put together you cannot tell the minute difference in each one. Albiet, the difference will be very small.
My 1 cents.
Ray Binnicker
David, There is another way safer than that.
Keith Newton
>First off, I think his choice of push stick may be fine for a TS, but something that can fit between the beds can be eaten like the tree-service limb chippers. And using another like he was using in front, looks like a good way to loose it.
Next, There is no reason to cut from the bottom first to the half, third, or whatever portion. You can clamp a stop-block to the infeed bed to place the trailing end against, to avoid kickback, then lower the leg down to the blade, making sure that some of it reaches past the cutter to the outfeed table. It will start cutting a very thin cut, which tapers deeper until it reaches the other end.
So if you want to take a half inch off, and do it in 1/8th inch increments, you just do the same thing four times, and they are all cutting down slope. If you find you are getting a little snipe on the front end, just save a little thickness to make a final thin cut by just feeding normally without a stop, after the taper is reached.
Re: Not for me.
Brian in Brighton
>Looks too scary for me to try. I don't like the idea of that much stock being chunked away. Might not be a problem with the wood he is using, but I would be leary of Oak or Walnut or another wood that might split out close to the end of the second cut.
He also says he can do 4 sides. I would have a tough time believing that unless he has a longer straight section to hold against the fence on the top of the leg. I would think having the stock not held against the fence would be a problem. Think about this on the 4th cut where the face against the fence would want to be a cut face, thus leading the bottom face to be a compound angle.
I'll stick to the TS and jog for this one.
Brian in Brighton
Patrick Schupbach
>3/8 is too much to take off.I think this process would work for a slighter taper.
I've done them
Joanne Adler in Pt. Pleasant, PA
>on the bandsaw and cleaned up with handplane. Mostly because I was too lazy to build a taper jig for the tablesaw (and I don't trust those little metal ones you can get for $20). But if you're doing 2 tapers on 4 legs, it just might be faster to build a jig. It's on my 'list'.
>I think doing them on my planer is a bit safer. I built a jig and I run all four legs through at once. I use double sided carpet tape to stick them to the jig. After I've finished one side, I rotate 90 degrees and do another side.
Re: David, There is another way safer than that.
Phil Smith
>The legs on stool in the attached link were cut with this method. The stool legs have maple veneer inlayed so that it only shows at the corners. The legs are tapered on all four sides. The nippling method allow you to keep the veneer aligned in the corners as the leg is tapered.
check WoodCentral Articles
Bill Tindall, E.TN
>I describe the technique in an Article. It is infinitely variable, fast, fool proof, safe, doesn't require anything but the jointer. I can't imagine that anyone that has tried it would prefer any other method. One can taper as much as desired by making repeated passes. One can even make reverse tapers where the bottom of the leg is large and the taper goes up the leg. And as a bonus the technique is the best way to make a convex edge into a straight one.
I have no idea what is meant by going up hill. All the cuts are downhill.
#141, to be precise____*LINK*
Rod Peterson -- Ormond Beach
>How to Taper with a Jointer
Before my time, by the way. you'd see fancy HTML fractions if I'd done it. Not to disparage any previous editors/assemblers/processors—some of these techniques are kind of arcane.
Rod
Where is it numbered "141"?
JohnKJordan in East TN
Re: Where is it numbered "141"?
>That's our actual article number. If you roll the cursor over the article title you will see in the status bar of your browser (very bottom bar) the link info of the article. In this case it'll say something like http://www.woodcentral.com/blah/blah/blah/articles_141.shtml. You will also see it in the URL box at the top of your browser if you access the article. The number has no particular application to the user, per se, but that's how they are named on the server.
Since I am in the midst of processing article numbers in the mid 800s you can see that it's a very early contribution (maybe even earlier than it appears because I believe the count started at 100, not 0).
Rod
