OT Shingle Installation
Kneale Brownson in sunny N. MI
>On a traditional three-tab shingle installation, the spaces between tabs line up every other row of shingles up the roof. As rain collects on the roof, it tends to form streams following the rows of spaces down the roof with the result the lower shingles tend to lose their aggregate material where the water runs most often. Tabs themselves will retain the aggregate while the shingle material under the openings will wear out.
This wear pattern has led me to apply "architectural" style rather than three-tab shingles because they have "features" that disperse the water better.
I just finished applying some three-tab shingles to a rental, where I tried to reduce the rain-streaming effect by making my row offsets a quarter tab instead of a half tab. The result is that the tab spaces are four rows apart instead of being every other row.
Any roofing experts here that can tell me whether this would be a good practice (other than the extra work of trimming row starters)?
Re: OT Shingle Installation
I've always done quarters. Never halves
Ray Thompson - Middletown,IN
>Too Bad you have already done it. Now the house is going to fall down. (Just kidding)
I don't see any problem with your approach.
I have been told that in Texas it is the practice to off set the rows five inches rather than six. This causes the slots to stagger or angle up the roof rather than line up. (Not sure this is really a "Texas" practice, but I saw a guy putting shingles on like this and commented, "You must be from Texas." He said, "How did you know"? This would also cause the slots to not line up and channel the water.
What you are concerned about also is the "side lap". Since you maintained four inches, I don't think there will be much of a problem. If the distance gets too small, water can seep sideways and find its way in. You did face them out of the wind, just in case didn't you?
DB
>When I learned roofing many years ago (to many to admit) We would start with a full shingle on the first row. Cut off 1" from the first shingle on the second row. Cut off 3" from the first shingle on the third row. Continue cutting off another 1" for each additional row. When you get down to the end of the shingle start over. Save all of the cut offs for ending the rows.
I once knew a person that reroofed his house. Did a very nice job except for one slight problem. When it rained one side of the house would leak. What happened was he went up one side with the roofing and when he got to the peak he just kept on going down the other side.
Yes. What you did will work.
