Anyone considered a table for your Performax?
>I went to the Woodworks show over the weekend and saw the Sand Flea (?) drum sander. This is a horizontal sanding drum with a table on top of it. You can adjust the height of the table and thus the projection of the sandpaper. I already have a Performax and small shop blues. It occurred to me that I could make a table to sit on top of my my Performax (with the hood open) and have whatever benefits this type of sander offers.
You can clean up dovetails with it. With a fence you can edge sand. You can sand the top and bottom of drawers. You can sand things too thick to go through the my Performax.
Anyone else done this? Sound like a winner?
Re: Anyone considered a table for your Performax?
Sand Flea
David Yoho
>That's an interesting idea, Barry. I don't know how possible it would be to do but certainly worth a look.
Regarding the Sand Flea, while I thought it was a nice idea and performed well, I just couldn't get past the price. The Sand Flea itself was about $700, then you pay extra if you want the fence, and more to purchase the hook and loop sand papers - all totaling somewhere between $800 to $900. I've got a lot more important needs for money like that than buying something else for sanding. As nice as they are, somehow I don't see them flying off the shelves!
Let us know how you make out with your idea.
David
Carol - now in NC Nebraska
>I, too, have been playing around with the concept of the Sand Flea.
While I have been in seminary and now on internship, I have been over a thousand miles from my shop. So I have been drawing plans and gathering information for future projects. (On internship I have my mini lathe, so a minor sawdust fix can be indulged!)
Anyway, I drew the plans (or at least most of the details) of a Sand Flea orientation sanding drum with a feeder head for parallel sanding, ala the Performax, but removable so sanding the objects you have listed could be accommodated. I, too, have a much smaller shop than I used to, and sold the Performax when I moved because of its footprint.
I know that doesn't help you, but I will be watching this thread with some interest.
Re: Sand Flea $700+??
>Wow, the price has skyrocketed since I last looked at it! I estimated the cost of my homebuilt at around $250-$300 (with motors) and it would do a lot more.
Hmmmm.... more research in order.
I just opened the hood and stared at it....
>I fiddled with it just enough to know you could put a table on it. It may have to be at and angle, high in the back and low on the front, but I don't see that as a problem. I think the existing hood would serve as a dust pick up, but it might require some modification because it would be resting on the belt of the Performax. The belt would not be running. I am thinking a piece of Baltic birch would make and adequate table. It could be fastened to the front rail of the support frame and rest on the rear rail straddling the hinges of the hood. Trying to envision an adjustment mechanism. It seems you would only need and 1/8 or 1/4".
Have a look at Stockroom Supply *LINK*
Charles R. Smith from Victoria
>There is a companny called Stockroom Supply that has been selling a similar product for a number of years. They call it a V-drum Sander.
It is a fraction of the cost of the Sand-Flee from RJR Studios. You need only buy the drum (and perhaps the sandpaper) from Stockroom Supply, and the rest can be bought either from them or made yourself. You have to source the electric motor yourself (which can save a significant part of the cost).
They sell a DVD that shows how to make one for $10 Cdn or $8.90 US. In fact, all of their US prices are cheaper than their Canadian prices, even though this is a Canadian company, located just across the border from Buffalo. And since the Canadian dollar is now worth more than a US dollar, this is a bargain for the WC'ers who live south of the 49th parallel.
Some years ago, I bought the basic parts for one. It is simple and it works. Besides handling thick pieces, it doesn't generate any heat when sanding with the result that the sandpaper lasts for years. There is little static charge, so most of the sanding dust falls into a small trough you make in the bottom of the case (which is easy to make from plywood or whatever you have at hand). In fact, I made the mistake of getting a large roll of sandpaper, and I haven't used it up yet.
If you don't mind doing a bit of the assembly yourself, this is the most inexpensive way to go. They are good folks who deliver great service.
Charles (who has no affiliation with Stockroom Supply, but likes their stuff)
Stockroom Supply's V-drum Sander
