Bench top Drill Press - Most bang for your $ ?
Charles Wiggins
>Howdy, oh wise ones.
I am slowly building up my collection of tools and I think my next major purchase is likely to be a Drill Press. My shop is TINY and I need a benchtop model, but I don't like the dinky ones I see in the Borgs.
Suggestions?
Re: Bench top Drill Press - Most bang for your $ ?
To do it again . . .
steve mackay
>I'd get a " slim " ( as I could get ) floor model and tuck it into a corner. More bang for your buck. But my old, all metal Craftsman bench top ( bought used with 3/4 chuck ) is still going strong after five years in this shop. And I ain't kind to tools !
Re: To do it again . . .
Ron Hildreth, Alta, Iowa
>Charles,
Right off the bat I bought Grizzly's Radial drill press (floor model), and I was glad I did, because my SIL wanted me to rebuild her childhood rocking chair. Everything from between the bottom of the seat to the floor was missing, so was glad I had the capabilities to drill the angles that I needed without having to make up any jigs. It was a time saver. If you think there might be a time in your future that you might like to build some chairs or rockers, a radial drill press might be a consideration. I wouldn't be without mine!
I've since made a better table for it, allowing me to drill holes into the ends of long pieces, plus lots of other applications I'll need it for. You can make tables like this for the bench-top models, but considering some of the things I've done on my floor model, glad I went this route, hands down!
Ron in Iowa
>Hello Charles,
I drool over that lovely radial DP Ron has, and maybe in another life could I justify one. No room for it, except if I part with my standard floor model press which I've had for years. I outgrew a small bench top press quickly. It was probably an 8 incher. Too small. The 10 and 12 inch models are nice, I bought #1 son a used Delta 12" in perfect shape and modest cost. I could probably make do with somethng similar if I had access to a floor model periodically. My recommendation is to get a floor model. And, if you can spare the space, get a Radial like Ron's.
George
Re: Bench top Drill Press - Most bang for your $ ? *LINK*
Dan Mitchell
>I've gotten good service out of this Harbor Freight model for general use. I think I paid more like $139 for it:
HEAVY DUTY 16 SPEED BENCH DRILL PRESS
Robert R Clough - Thorncraft
>Recently I sold my floor model Grizzly radial DP and purchased a Ryobi DP12L. It is inexpensive, has laser X mark, digital speed readout, and a continuously variable speed. So far so good. Seems to work well.
Bruce, a MN Galoot
>You're smart not to go for the tiny ones at the Borgs. A whole bunch of years ago I bought a POS crapsman 6". It was on sale and I needed one. Problem was, I headed into that purchase with far more enthusiasm than thought and ended up with a cheap DP that doesn't have enough capacity to handle most any job I ever threw at it. The only thing it's really good at is to hold a small sanding drum.
I second the notion of a floor model. However, I also understand the needs of a small shop. Mine measures about 10 X 10, with the option to kick my wife's car out (under great duress, mind you).
If you go for a bench top model, don't get a small one. Be sure that you have enough room under the longest bit you're likely to use to actually put some piece of wood on the table. I say that because I can't use a jobber length bit and still put anything on the table of mine. I would guess that you would need a minimum of a 2-foot column, maybe 3. Also make sure the column is beefy enough to handle any wracking stress of punching a whole through something tough.
By the time you end up spending the money it takes to fill those requirements, you're pretty much to the price of a floor model. That's my next big tool purchase.
Bruce
Re: Floor Model DP
Charles Wiggins
>I have this post on Saw Mill Creek as well, and so far getting a floor model is the leading recommendation all the way around. My plan is to build a mobile cabinet with storage on one side, and mounting tracks on the other side, for holding tall stock or an auxiliary table if I need more depth. That way I can get all my drill accessories out of my main tool locker (which is getting crowded), AND I'm getting more use out of the floor space.
