UHMW Super slick tape question
>I read somewhere that you can use the high density plastic tape to make drawers slide better.
Has anyone done this? Did it work? Did it last a long time or did it peel off after a few cycles?
I have some drawers that are slightly loose and this might be an answer. Where do you get it?
Re: UHMW Super slick tape question
Patrick Schupbach
>Rockler sells this by the roll. I used it when making some oak dressers.It works. Hope this helps.
>Barry,
I've used it that way, but if your bearing surfaces are sanded and finished, a little wax does just as well. I've also used it as a C-H to tighten up side-to-side play of the drawer if my fit got a little sloppy.
mm
[admitting my drawers aren't perfect in New Jersey]
Allan Campbell
>Not to change the subject too much, but if we can't seem to find an adhesive that will bind UHMW plastic to other things, how the heck do they make this tape stick? And, can we get the same adhesive, or something similar, to use making jigs with UHMW parts?
>Contact cement works pretty well as will a number of soft flexible adhesives. The water based and other hard-setting stuff releases and fails. You can help the "stick" by scoring the glue surface with heavy grit paper and/or a razor knife.
mm
>There is a show on the DIY Network with Amy Devers, called Freeform Furniture (I think). She made several pieces that involved heavy polyethylene sheets. One was a chair and the other an end table. She used heavy duty double stick tape on one project. Not sure about the other. I think the tape came from 3M, but I am not sure. You might try looking the show up on the DIY web site and see if they have a list of products. If I see it again I will take notes. I did not know there was going to be a quiz.
