Re: Mark G.? John Weber?
Al Stokka - Cambridge, Iowa
>Dave,
Diggin through Mark G's website and my Badger Pond Archives CD, here's what I find:
BP Archives, by Mark G., July 1, 1999:
"The Uniguard splitter is black and uses a big thumb screw, so you must lift the throat plate to insert AND remove. The Biesemeyer is a little fancier, it's silver with some white paint, and it can click in without removeing the throat plate, but you must still lift it to get at the spring loaded knob to remove the splitter."
"The Biesemeyer splitter is a better splitter (plus there are 11+ models so it might fit a PM saw for instance), but $29 compared to $109 the Uniguard splitter is a better deal."
BP Archives, by Mark G., July 2, 1999:
Uniguard splitter: "part number: 1349941 SPLITTER ASSY COMPLETE"
BP Archives, by John Weber, July 1, 1999:
"I have the Uniguard for my Powermatic 66. I modified the splitter to work on the left-tilt PM, and used the standard PM hardward to bolt it in place. It's easy to remove with a wrench I keep in the guard basket. Best of Luck with your new PM 64."
I have the Beisemeyer splitter. I particularly like the ease with which it can be installed and removed with a sprin-loaded pin. The Uniguard splitter, I find, requires loosening a thumbscrew to install/remove the splitter, but then, the Uniguard spliter is cheaper (through Delta parts department) so I guess you have a decision to make.
Hopefully John and Mark will jump in here.
Al
