Comments wanted on 10 inch dado set
marc rosen
>Hello All,
I saw at an estate sale a 10 inch stacked dado set (I think it was Amana)in unused condition. I have only used 8 inch stacked or wobble dado sets in my table saws (10 inch craftsman and now Unisaw)and I want to know if anyone has any comments on using this set in the Unisaw. There is no table saw at the estate sale and the owner does not know what it fit in. Thanks in advance for your comments.
Marc
Re: Comments wanted on 10 inch dado set
Dale Lenz
Dale Lenz
>The arbor hole in the ten inch should be the same as your older 8", check them out. Very few people need the depth of a 10" dado set, but in theory I'd think you might get a smoother bottom cut due to the increase rim speed of the 10" diameter over the 8". On the other hand you will get more FLUTTER or is it WOW, :"> side to side movement with the 10" over the 8 inch.
>I have had an eight inch set for years. What I have heard about ten inch sets is that they are heavy, significantly heavier than smaller sets and any vibration, fluttering, wobbling, whatever will be worse and will not only affect the cut more so, but will put more stain on the shaft and arbor. After about forty years of owning a 8" set, I can not recall a case of needing a larger set. You/I just don't cut dadoes deep enough that an eight inch set won't do the job. (I'm trying to convince myself that I am over my size envy here, but I would have bought the set if it were priced right.)
Lee Grindinger
Size does matter
Lee Grindinger
>As Dale said, tooth speed on a ten inch diameter set is greater than that of an eight inch set so cuts will be improved. The ten inch set will give you greater cutting depth which I find very useful for mortise and tenon work as well as spline work.
But, here's the caveat..., Delta Unisaw throat plates will not readily accept a ten inch set. The ten inch set will not lower below the throat plate because of it's thickness. The set will lower below the table surface but not the underside of the throat plate. There are safe ways to deal with this and not so safe ways. Cutting the groove in the throat plate with a sabre saw is the safest way, lowering the throat plate onto a spinning blade is the not so safe way. This means that zero clearance throat plates are not practically possible with a ten inch set.
As far as flutter and such, it's a dull set that causes this and once spinning the ten inch set creates no more stress on a Unisaw motor than an eight inch set. With that caveat noted above I've always opted for the larger set. A three horse motor can cetainly handle a ten inch set.
Lee
marc rosen
>Hey Dale, Barry,
Thanks ,for your comments. I never considered vibration a factor and the need to cut a deeper trough has never been an issue when I was using a dado set. However, the set looks unused and I was thinking it would be a good deal to buy it if I ever needed to replace my current stacked set. I hope common sense tells me to spend my money on something I will use now, as compared to later or never.
Marc
Make your own throat plates....
>Since you already have an eight inch set, you could make up a bunch of throat plates and precut them with the eight inch set in various widths and set them aside to use later. All you would have to do is make them and raise the 8" blade(s) through the plate a little to create a cavity in the bottom side for your ten inch set. A bit of a PITA, but not so much if you really like that ten inch set.
Mike Fitterling
>A ten inch may have a 1" arbor hole. At least in one of my pro catalogs the 10" dado set is for a 1" arbor. Could be some out there for 5/8" though.
Charles M
>There are VERY few 10" saws that will accept a dado larger than 8" and many won't accept larger than 6". Check the user's manual for the saw to be sure.
