THE WOODRAT IS BACK!
Porter Cable FR350 nail gun update.
Ray Carson, Lawrenceville NJ
>Fellow WoodCentralions',
Can anyone tell me if my older model FR350 Round Head framing nailer can be updated with the round, little red wheel thingy on the trigger. This newer feature makes it posibble to nail continuously while holding the trigger. Basically, bump and nail method.
I tried th PC www.support thingamabob and didn't have much luck.
Tanks,
Ray
Re: Porter Cable FR350 nail gun update.
>Ray,
Yopu're talking about a "sequential trigger" used for bounce firing, and yes your gun can be fitted with one. Indeed, most all framing guns come with both triggers (easy to change) with one being gray or tan and the other red or orange. As bounce firing was one, if not THE greatest source of nailgun injuries, I think some makers switched to have the the safety triggers standard and the bounce trigger optional.
PC will have the trigger as will places that cater to contractors; try Updyke. You put one one, please be careful, eh?
mm
Re: Sequential firing respose from Mark
>Hey Mark,
I was really curious more than anything. Never in a million years would I want a "bump and run" framer. Now, my finish nailer has this feature and I love it. Two guys I work with just bought the FR350AB packages and I never saw this feature on a framing nailer. Like I said, I was just curious if it could be done.
Good information to have. Thanks Mark. :-)
Ray
Race
>In case you're wonering, Earnie and I are in a rrace to see who can incorporate morr typos in a message and still hav it readibable.
[Jeez, I've GOT to get a proofreader]
mm
Alan in Little Washington (NC)
>The FR350 was designed to work with the sequential tap fire trigger or the single fire trigger. But, I bought and installed the selectable trigger. While it is not designed to fit, by carefully drilling a new small mounting hole I was able to mount the selectable trigger on my older FR350 anyway.
Jason Roehl in Lafayette, IN
"Single-fire" IS "Sequential-fire"
>I have a Stanley-Bostitch framing nailer that came with both types of trigger. "Bump-" or "bounce-fire" is the name for being able to hold the trigger in and fire a nail every time you compress the nose safety. Of course, this is the more dangerous mode, but much faster, especially when nailing off sheathing. "Sequential-fire" is the safer mode, as you must compress the nose safety, then pull the trigger in SEQUENCE each time you fire a nail (and you can only fire one and not another until both the safety and the trigger are released).
I switched mine to the sequential trip, as I am not a production framer, and I am a gun shooter ("squeezing" the trigger on a nail gun will often cause a double-tap).
Jason
Re: Have the same problem "squeezing "
Larry Clinton
>the trigger like I do firing my guns. My son's Hilti framing nailer has the bounce-fire trigger. I really found it disconcerting when it fired a second and /or third nail in an unwanted location. I finally got used to using it without firing unwanted projectiles. I don't know why it would be an advantage (certainly wouldn't be to me) when framing a building. I like to place each nail exactly where I want it when framing. Course I was raised in an era when if you wanted to drive nails faster you just got a heavier hammer. Built one house that way, with the sub-floor and roof sheathing 3/4" thick 1 X 12's - an air nailer would have been a godsend but were not available at the time.
Funny you should ask that........
>A few months ago I bought a new PC FR350 nailer. Unlike my 3 other PC nailers which come with a plain RED trigger, this one came with a black trigger with a little round switch that let's you choose the type of firing method. I understood that this is the more versatile trigger, preferred by professional framers, since you can switch it to the faster but less safe method. In the manual it said something about this and that if I prefer to have the plain (safer) trigger instead, they will send it free of charge. Knowing that I'll never use it professionally nor need the speed, and since I prefer the idea of safer, I ordered it.
To my surprise I erceived the exact same trigger as it came with. I'm going to have to re-read the manual again to see if I misunderstood, or if they sent me the wrong piece.
Happy Woodworking!
