Where is the water going? - Update
Ray Carson, Lawrenceville NJ
>I just saw the thread I posted bout a week or so ago and Tim Greif - West of Chicago wanted to know if I found a solution. Well....(pun intended)
Part (most) of the problem was a faulty water meter. Long story short, the local public works people ran some tests and sound equipment on the water meter and found it was faulty. Ah...DA! the meter was 25 yrs. old.
Also, we had a sneaky toilet here at the office that unbeknowst to us was being used by the cleanig crew or cleaned by them AND the flapper thingy (plumbing technical term) would stick after they left. The rest of the story is water down the drain.
So....there you have it. New water meter and a new toilet, and we are consuming much less water.
For those of you plumbers asking why not just replace the flush mechanism.....well....we replaced the whole toilet because this particular model was very hard to get parts that matched and worked well. We were constantly running to the hardware store, plumbing supply house or box stores and trying to retro-fit parts that really didn't work.
Ray
P.P.I.N.G, LLC
"Plumbing - Problem - Investigator - Noitall - Guru"
Re: Where is the water going? - Update
I know its not funny but . . .
steve mackay
>Guess I was looking for some spooky, wierd, " Outer Limits " explaination. Glad you solved it though ! Water sure aint cheap any more !
Sorry to dissapoint you Steve :-)
Ron Hildreth, Alta, Iowa
>Ray,
Good to hear you got the water mystery solved! Thought about that the other day, and was worried it might have gotten away from you and you were busy treading water!
Thanks for the update! At least now we won't have to send the Coast Guard!!
Ron in Iowa
Good to know Ray, and a comment....
>For my day job, I'm an engineer in the water and wastewater industry. These things inerest me. What's puzzling is that most consumer water meters are specifically designed to err in favor of the customer. They're not terribly sophisticated or expensive (around $50) and the design is such that as they wear out, they start running slower, under-registering the water flow. I can't for the life of me figure out how a standard grade consumer meter would speed up and register more flow than actual. But then again, there's alot of things that still puzzle me. I guess that's a good thing.
Glad you solved your "leak".
Hey Ray
>You seem flushed with achievement. :<)
George
