>I have been making guitar stands out of bentwood laminations of walnut and have used Titebond for the glue. I have several small areas where there were not enough clamps or I did not get good contact. (Bad on me!) I know you can put yellow glue on veneer and let it dry and then press it on with an iron, or at least I have read that. Never done it myself. What are the chances I can heat the places of my laminations and melt the glue with a heat gun and clamp them back together? The areas in question are not under a strain. Any other ideas for improving my crappy workmanship? (And yes I promise I Will do better next time.)
I wouldn't trust the heat-formed joint. I think the glue line will be too thick to stand up to seasonal movement. I've used the iron-on technique for veneer. I speculate that it works because the glue joint has very little stress on it.
Bob S. has an article about glues in the article section. I think he recommended epoxy for regluing a joint containing yellow glue, but do read it in case my memory is faulty.
>I know this doesn't help you with your current situation, but this is another reason I love using hide glue. Besides being good about not allowing a bent lamination to move, it's always easy to undo for repairs.
>David, I have been thinking aobut using hyde glue. It ahs to be heated to use it doesn't it? Is there a cold version that works well? Wonder if it woudl have enough open time to get six 6" by 48" laminations coated and bent?
>Barry, the side benefit of using the Titebond Liquid Hide Glue is that it is formulated to allow a little extra open time. That's not to say you can't add something to extend hot hide glue open time but I prefer the convenience of the liquid. I think once you give it a try, you will like it.
>Barry, I use mostly Titebond 3, Titebond liquid hide glue and some hot hide glue. (Also use some CA, LV cabinet glue and epoxy on occasion). The Titebond liquid hide glue IMHO, has about the same open time as the Titebond 3. The hot hide glue open time can be extended by heating the area to be glued and some additives can also be added. (I haven't tried this as I usually don't use the hot hide glue on parts where I need a long open time. I don't know how the regular Titebond or Titebond 2 compare as I don't use them. (I find it easier and cheaper to buy the Titebond 3 in a gallon - then pitch whats left after a year or so.)
As a frequent lurker, I see a post that I can somewhat contribute to. I have used "Old Brown Glue" (hide glue) with good results in the past. I just put the bottle in warm water before use.
I have not used it on bent laminations yet, but I have used it where I have needed extended set times, and have reversed joints with water and heat.
