Re: ???????????? OT - DVD on PC using MS Vista
Tom
>That depends on the content.
If they are just data dvd's with some of your data on it, just open the 'd' drive, hold the ctrl key down and select each file you want to move. When they are all selected (if it's all of the available files, ctrl-a gets all of them at once), hold down on the last one you selected and drag it to the 'c' drive or whatever folder you want to store them in (of course, you'll have to create the folder first and have it open).
If it's copyrighted material (ie, movies) it's more difficult. Dvddecrypter will work on older movies (file or iso mode, then 'read'). Newer ones will require something along the lines of Anydvd ($40 or so) to be used in conjunction with Dvddecrypter (free).
The problem is, of course, Vista. M$ has gone nuts with DRM. I have two pc's with Vista that will not even PLAY a dvd using the M$ media player (not a problem, there are better free media players available for free). As for ripping, I'm doubting it. I use one of my XP boxes for that. To tell you the truth, I'm not sure if Anydvd or Dvddecrypter are Vista-compatible.
As for the legality, you can do anything you want with your data. Copyrighted material (I believe) can be copied for your personal use according to fair use (despite the FBI warning) provided you own the source and do not disseminate it. That is my understanding.
