Have a question? Ask Woody!
removing paint from old hardware
Ernie Miller
>is there an easy way to remove old dried on paint from old door knobs ans hardware? there is alot of interesting old hardware in this house I am redoing and would like to reuse it but only if it can be cleaned easily. I like the looks but time is money and I have little of either to spare. it is all removed for the doors to make fro easier painting and cleaning so a soak and wipe treatment would be cool with me.
Re: removing paint from old hardware
Lee Schierer - McKean, PA
>Soak the pieces in either paint remover or lacquer thinner for a while. Either one should soften the paint where it can easily be removed with a soft brush.
Lee
Re: I might add....
Ron Hildreth, Alta, Iowa
>Lee has a great idea, and if I might add, follow that with a power washer to strip the paint off that the paint remover left behind. Follow that with a blast of air to blow out the water, then some spray lubricant, and you should be good to go!
Ron in Iowa
Re: I might add....
Ernie Miller
>will I need to respray the brass with laquer if I do that?
Re: I might add....
>Ernie,
I can help you get the paint off, but someone else better help you with the laquer question. Seems everytime I think I know something about a certain finish, someone proves me wrong. Sorry!
Ron in Iowa
geary
>Last june,I found a whole fleet of rusty metal tonka trucks in the trash. Needed to find an easier way, than sanding, to remove the paint and clean up the rust spots. ENTER TONKAMAN!!!(@ebay guides for paint removal for metal toys and car parts.)You might want to go there for all the particulars,but here it is in a nut shell....mix 2 gallons of muriatic acid to 22-24 gallons of water in a large rubber maid container(with lid) I know this is a large batch, but I had a fleet to do.Besides,put a lid on it...it won't go bad,OR, mix a proportioned smaller batch. You can get the acid at any pool store(honest)or a building supply store in the masonary section. Hang your hardware on old clothes hanger hooks and wear rubber gloves. You will not believe the results!!!! Be ready,after 24 hrs,to dry and prime right away. My trucks were perfect after 24hrs. Hope this helps you, its a short cut I will be using many times in the future.Geary
Boiling water and a little detergent
Forrest Addy
>Boiling water and a little detergent will soften accumulated paint and a little work with a small wire brush will remove it.
If you can handle a little kidney damage toss the all metal(!!) items in a 3 pound metal coffee. Add a quarter cup of lacquer thinner, cover with the plastic lid, and let it stand over night. The paint will swell up from the vapors and be removable by scrubbing with a brush.
Do not use this method with plastic or glued items. Wood in most cases will be unaffected but it have to be allowed to expel the vapor residues for a few days before re-painting.
patina? *LINK*
Bob Falk, FPL wood engineer
>Hi,
I have a 20's Tudor that I have worked on the hardware....careful with the lacquer thinner...as suggested, it will work well to remove the finish, however all the old patina will go with it. If you want bright shiny hinges, that's ok, but if you want to keep the aged look, I would suggest a boiling water soak to try to soften latex...or, just try to chip off the paint and retouch with a varish/stain mix to hide the bright spots. Paint removers, even the citrus blends, can discolor the metal.
Bob Falk - Author - Unbuilding: Salvaging the Architectural Treasures of Unwanted Houses.
http://www.taunton.com/searchTaunton/searchStoreResults.aspx?searchfor=unbuilding
Re:I knew there was someone that knew more!
