>I RECENTLY BOUGHT THE LAGUNA 16 HD BANDSAW WITH IT CAME A 1 1/4 RESAW MASTER BLADE. WHICH WAS DULL AFTER FIRST CUT.I DONT KNOW WHAT CAUSED IT TO GET DULL SO QUICK.I SENT THE BLADE BACK TO LAGUNA TO BE SHARPENED.WHILE WAITING FOR BLADE TO COME BACK FROM LAGUNA I CALLED MY BLADE VENDOR TO ORDER NEW BLADE.I WANTED A 1" BLADE HE TOLD ME A 16" SAW WOULD NOT BE ABLE TO TENSION THIS BLADE PROPERLY. AND THAT LAGUNA WAS USING THESE SAWS WITH THESE BIG BLADES AS A MARKETING STRATEGY.I DONT KNOW WHAT TO THINK OF THIS I WANT TO USE THE SAW WITH THE BIG BLADES.DOES ANY BODY HAVE ANY EXPERIENCE WITH THIS.
>I'd certainly want to check out why your blade went dull before installing another. The fella should have a blade tension gauge to loan you with a spec on his blade. I'd invite him over for a cold one or two to investigate. He might bring a few blades with him. Hint Hint
>YOu know dave, you took the words right out of my mouth... It's refreshing, but embarrassing to do an obviously dumb thing,and know that someone else may be capable of the same mistake when trying out a new machine. Does that thought make any sense? geary
>Another wonderful way to toast a blade real quick is mis adjusted guides that rub on the teeth. Make sure the side guides are set back enough and the back bearing is set so the blade doesn't get pushed into the guides.
>Sorry scott, I called you dave, but you ask a not so " smarty pants" question. Every time I think I'm fairly intellegent...I do something to prove otherwise.geary
>Dave- My experience with Laguna may help here...though it's several years old. I bought the 16" regular, not HD, and the blade it came with was crap. I called and was told by a salesman these saws are sometimes shipped from the manufacturer with 'test' blades on by mistake, just to secure the wheels during shipping. They replaced it immediately. I've loved my 16" Laguna, and have used the wide resaw blade almost exclusively with no problem. It tensions all blades very well. -BarbS
