>Quite a striking table. I've often thought about doing this with decorative tiles - there are just so many gorgeous (but pricey) tiles available. How did you fasten the tiles in place? Tile mastic? Construction adhesive? And did you grout between the tiles and along the outside perimeter of the tiles? If so, with ordinary grout? Sorry for so many questions. And good luck at the crafts show!
>Thanks. Used PL Premium construction adhesive. The grout is only in the center sections. The tiles butt right against the sides and looked good so I didn't put any there. Used ordinary wall grout.
>Nice job! I especially like the "floating" look to the top.
I have made several tile-top tables and have one suggestion -- there is some stuff you can get that protects the grout from staining. I don't have any at the moment, so can't give you the name, but contact a place that sells tile and they should be able to supply you with some.
