Veritas - Innovation in Tools
Seeking ways to hang stepladders.....
R. Lance in GR, Michigan
>I want to hang three fiberglass Werner stepladders (8', 6', & 4') from garage wall...best thing my simple mind has devised is a 2x6 screwed to the wall with 1" dowels protruding from the 2x6 at an angle over which the upper step/top of the ladders would go suspending them (2 dowels/ladder)...I guess I'd like to know if there is a product out there for doing this...or if anyone has a way that they've done it...pictures please if you can...thanks for any help.
Re: Seeking ways to hang stepladders.....
Jason Roehl in Lafayette, IN
>I have a BUNCH of ladders I just hung off my block garage wall. I used 3/4" pre-threaded galvanized pipe mounted with u-straps so that if I ever took all the ladders down for a job, I could fold the pipes back against the wall and out of the way. I made two hangers, each of them 'E'-shaped, with 2-foot sections for the spines and 18-inch sections for the horizontal pieces. They were connected with the appropriate elbow and tee fittings, with an elbow on the end of the horizontal piece to prevent the ladders from sliding off. The middle section usually holds a 28-ft Type IA aluminum extension ladder (60? 70? pounds) and a 35-lb Little Giant.
However, I would think it would be much cheaper and easier to just go in the shelving section of your closest Borg and buy some steel, rubber-coated hooks if you only have 3 small ladders.
Jason
Dale Lenz
Dale Lenz
>I did as you are suggesting but I used 3/8~1/2" rebar in place of the dowels. Drill an upward angled hole the size of the rebar minus the ribs and pound in like a nail. I've hung a few heavy things using rebar, after building the shop. As always use what you have available.
Jay St. Peter - Southern, MD
>Warner makes metal brackets for like $6 at the borg. If you want to hang all 3 at the same spot that wouldn't work, but it sounds like you want to hang them all next to each other. The nice thing about the bracket is it holds them tight to the wall. The down side is that they only hang one way (not that big of a deal once you start remembering which way).
Jay
>Those are exactly what I use and they work great. I decided it was cheaper than anything I could build and took me 5 minutes to install.
Don Bullock
>My step ladder just hangs on a nail. It works for me.
Pete in Holland, MI
>Take a 2x4, about a foot long, and rip one of the 1.5 x 12" edges to about the angle of the top step when the ladder is folded and standing vertically (about 20 degrees or so). Attach a piece of 1/2 x 4 x 12 plywood on this ripped edge, with the edge hanging out from the taller side of the 2x4. Screw this to the wall. Hang the ladder with the people side of the ladder toward the wall from the underside of the step. Works well for my 3 ladders.
Pete
>I looked thru my catalog from Seven Corners/Tool on Sale which has a large section on stepladders for just such a bracket...nada...off to the borg tomorrow.
16p nails
Ron Jones
>I once asked a kid working in one of the borgs (won't mention which one, but I am not a Tony Stewart fan)if they carried a "left handed number 3 skyhook with a reverse barb". Told him I wanted it to hang ladders. I think everyone in the store knew what it was and where it should have been but him. The manager laughs every time he sees me.
