Heat-Activated Fire Alarm
Yonak
>Does anyone know where to get one ?
Re: Heat-Activated Fire Alarm
Re: Kidde
>I contacted Kidde with this request. They sent me this.
"Thank you for contacting Kidde with your fire protection needs. Due to the dust in a workshop a regular smoke alarm cannot be used. Instead, if you install a heat detector, an HD 135 hardwired to a regular smoke alarm, that would provide the protection that you need in that location."
They are available at Amazon among others.
Re: Kidde
Edward in Vancouver
>As a chef and restaurant owner, I am familiar with fire supression systems. What you see typically in a restaurant is basically a tank and nozzels. A tensioned steel cable is suspended over the cooking equipment. The cable is a series of lengths soldered together with plain lead solder. When the heat gets to a point around 350 F, the lead melts, the cables go slack and trigger the chemical,simultanously (sp?) shutting off the gas and power as well. No reason you couldn't rig up something, check around for fire suppresion guys.
Not to quibble, but....
Gary Camp, Bend, Oregon
>If one wanted fire surpression, not just a heat activated alarm in a shop situation I would go with a typical fire sprinkler system. It is much cheaper to install and maintain. It would trigger at a lower temprature, 160 ish depending on the head, and should it ever actually be triggered water is a LOT easier to clean up than a cook line system. Having a cook line system (Ansul not Kidde)go off, say, on saturday, during Christmas vacation at 11:30 am at the burger station of a moderate sized ski area is not a fun event. DAMHIKT. The fuseible links to shut off gas and / or power are a great idea though.
glc
Filtrex *LINK*
Tim Greif - West of Chicago
>Take a look at the second detector in the link below. The Filtrex type is designed for dirty environments that fool normal ionization or photoelectric detectors
Detectors
DB
>I read something the other day said Fire Officials in the early 1900's recommened putting firecrackers in the attic, walls and flooring. If you had a fire the firecrackers would light and explode in order to wake you.
I wonder if it ever really worked.
