Ever wash a jump drive? (OT)
Lee Schierer - McKean, PA
>I left my 1 Gb Sandisk jump drive in a pocket and then it went down the laundry chute. It ran through the washer (front loader). Any ideas on how to dry it out?
Lee
Re: Ever wash a jump drive? (OT)
Michael Wangler in Rochester, NY
>Lee,
I usually find mine after it goes through the washer AND the dryer. Two of mine have gone through with no ill affects. I would dry it anywhere warm and dry.
I'm sure it will be OK.
Michael
Binen
>Place it on a cloth or paper towel. Keep away from high heat sources, such as hair dryer, direct sun or oven. Yes, I do know people who have tried to dry them in an oven and microwave. If you have a can of dry air blow it out. It should be fine in a day or so.
Binen
John McGaw
>I've never washed a jump drive but I have washed and dried a bare 512mB CF card with no discernible ill effects. I'd just set your drive aside in a dry location for a few days and then try it. If it has a cap over the connector, you should probably remove that so that any trapped water can evaporate.
Bill Howatt
>Before doing the actual drying you might give it a good rinsing in distilled water to remove any residual soap or other stuff that might cause corrosion of leakage between printed traces or pins.
Electronic components that don't have moving parts like relays are very tolerant to water, it is the boards they are mounted on and connectors that cause problems.
Years ago we bought a very expensive Hewlett-Packard digital voltmeter. The manual mentioned being very careful with certain parts of it due to possible leakage problems caused by dirt. Since we had a high-class clean room facility available we asked HP for cleaning instructions. Reply was that all of the electronic parts were approved for cleaning in normal dishwashers. So much for the fancy clean room.
Bill
I hate when that happens. What I do
Dustmaker Mike
>lets see when I get a coffee spilled into a keyboard I wash in warm water and dry in an oven at about 100 degrees. Warm dry heat should do it keep it at about 100. All the jump drives I have are pretty well sealed so I wouldn't worry to much. Just dry and try. Good Luck
Suspend on towel over low wattage lightbulb
Kneale Brownson in sunny N. MI
Stephen Kirk in Quakertown, PA
>Mine get washed a lot, through the dryer too. Not a bit of data loss, but if I used fabric softener my files are so soft and fluffy ...
