>I'm looking at a Jet JJ-6CSX 6" 3/4 HP jointer on the used market from an individual, asking price $275. Includes mobile base. If anyone has had any experience with this jointer and can advice me on whether or not this might be a good purchase, I'd appreciate it.
>Several thoughts. If it is the jointer I'm thinking about, it should be a 1 hp, not a 3/4 hp.
My favorite tool dealer offers the Jet Model JJ-6CS, 6" Closed Stand Jointer for $449. So is $250 a good deal? Maybe. Depends on how new it is.
I think the bed is a bit short. I would want longer infeed and outfeed tables. I would also want a bit more mass.
Think about the future. Is this a temporary jointer? I mean are you buying it because it is a deal now with thoughts of upgrading later? If so, you may be happy with it.
>I agree with JL.....double check the model and the HP. Jet offers a closed stand version with a 1hp motor and an open stand model with a 3/4hp motor. Both can be functional tools, but the closed stand model has some advantages and would be a better deal at $275 if in nice shape. $200 for the open stand version should be closer to a "good buy" IMHO.
>Dan, I don't know the particular jointer so I can't answer any questions about that one, but in general there are three or four important things about a jointer.
The beds must be reliably lined up with each other either so they are coplanar when the jointer is at zero or in parallel planes when it is set to cut. Longer beds are better than shorter ones.
The knives must be set accurately so that they are parallel to the bed and each one is exactly the same height.
And you need a good sturdy reliable fence.
My understanding is that the older dovetailed slide adjustment mechanism is slower but easier to adjust on a tiny microadjustment basis. The method that sues the parallelegrams to adjust the beds is faster but nearly impossible to change by a very small amount, (a few thousandths). This becomes important when you change the knives.
If your cutter head is milled accurately you can just drop in the knives and then adjust the outfeed table to match. On the tables with the dovetailed ways, this is little more than turning the knob, but on the ones with the parallelegrams, it is nearly impossible. I do not know how this affects people using one of the quick change knife setups or the Spiral cutter heads, but think about it.
In day to day use, a few thousandths does not matter much but if the setup of the knives V the outfeed table is wrong you either get tapered work or snipe. Believe me, a major PITA.
So based on that, I would not buy a jointer with the parallelogram adjustments.
>Yes, it is a good tool. Price seems fair for 1 HP model, in fact, good if the extra blades are tossed in (I just sold one with 2 extra blades - mine was very lightly used). I bought this over the comparable Delta unit as is seemed a little more robustly built. Never gave me an ounce of trouble, aligned right when I got it.
I would say go for it if it is in good shape. I only sold mine cause I got a deal on an 8" jointer, or I would still have it.
>Dan - I've got the little JET open stand jointer and I think it's 3/4 HP as well. I bought it used for $250 about 6 years ago. Funny thing - I've never cursed it for lack of power and always expect to.
But I have cursed it for being too small, both in the length of the tables and in the width of the bed. The thing can be downright scary when starting a pass or finishing a pass with an 8' stick.
I'm on the prowl for a good deal on a used 8" and while the 6" will work for you and you can probably get (most of) your money back out of it if you keep it maintained, I'd opt for an 8" jointer if you have the room.
>Thanks for the replies. The ad says it's 3/4 HP, which did concern me a bit. It does have a closed stand though, here's the pic of it, currently disassembled. I've just started looking at used, based on what you guys are saying I think I'll keep looking. I had a Delta 6" "professional" jointer I bought in 2000, along with a Unisaw. Never used either much, not enough space, plus we ended up moving across the country & I sold both on Ebay. I am leery of jointers because of my experience with this Delta. The fence was warped, a common problem at the time. I complained & they sent me another fence, just as warped as the 1st. Really put me off Delta & made me "fear" buying a jointer. Thought maybe an older one (like this Jet appears to be) would be better. If I could afford it, I'd get the Powermatic 54A 6", but 800 bucks! ;-(
>Thanks Barry, I'll keep the parallelogram/dovetail aspect in mind. My experience with jointers is limited to a Delta 6" "professional" with a warped fence (2, in fact, the replacement fence was ALSO warped) so yeah I'm very keen on making sure everything's "straight". Thought maybe an older example would be better in this regard. Maybe not, and maybe this one's not "older" enough!
>I would sure look at the Grizzly - I would also save up a few more bucks and opt for an 8". I sold my old 6" Griz (about 10 ~ 15 years old and still flat and straight as a die) to a friend last year and replaced it with the 8" Grizzly G0 593 with the segmented carbide cutter head. The bed is completely flat ( within .002 in 75" checked with a Lee Valley long straightedge). Fence is straight enough for me, one corner is off about .003" (checked with B&S machinist square and feeler gages. The surface of joined product is unbelievable, especially with curly woods. I am not a huge fan of parallelogram planers, can't see the extra cost for the minimal advantage of easier alignment. I hardly ever reset my jointer depth, once I get a surface flat enough for the planer I square up an edge and move on. I then plane and saw the second edge. I had the lever adjustment on the 6" ~ wheels on the current one, can't really say I prefer one over the other. IMHO, a longer planer bed length makes it much easier for me to flatten longer boards. I have done it on my old short bed and my new long bed and there is no comparison as far as ease of operation.
>That's my understanding about the older Delta stuff. Even though my Unisaw seemed fine - though I didn't really do much with it in the brief time I had it - the experience with the Delta jointer really put me off the brand. One reason I got a powermatic TS this time around. I'm new at this, I make enough mistakes on my own, I don't need some sloppy tool helping me in that regard.
>I've looked at other Grizzly tools, most recently their 2hp dust collector, but have never bought one. I know many swear by them. I'm glad to hear your positive experience, especially with something requiring optimum precision.
>I think that if you search the site here (including the archives), you will find that many consider that Grizzly product quality is at least as good, if not better than Jet, Delta and other major imported brands. As I said I had their 6" jointer, replaced it with their 8" and also purchased the Griz 3 horsepower cyclone. I did have some issues with the motor start switch / capacitors on the cyclone, but Grizzly did a good job correcting the situation. Personally, I think Grizzly has some of the best value equipment on the market, and their part stock and service is at least as good as any importer. I do own other brands of equipment, Delta Unisaw, Fisch benchtop morticer, Powermatic lathe, Delta drill press and table sander, Dewalt CMS, MiniMax MM 16 band saw, Yorkcraft & DeWalt planers etc., so have some basis for comparison.
>At the time that Jet jointer was made, the Griz 1182 jointer was made in the same plant in Taiwan, and are very, very similar....both of these models, as well as other models from the same plant have always been well respected tools.
There are similar situations with many different tools and brands across the industry....sometimes the biggest difference is warranty, retailer, color, and a few other cosmetic things.
