200+ woodworking book reviews
Plunge router Slipping Question?
>I have a PC 7529 plunge router. It has the switch on one handle and a lever on the other side that locks and unlocks the plunge mechanism.
You push the lever over to the body of the router to lock it and you pull it out to unlock it. The lever is a sort of contoured wrench around a hex "nut". The locking mechanism is no longer secure. The router creeps up.
Is there an adjustment? Can I take it apart and reassemble it so that it works as it should? is there an auxiliary lock on it? Sometimes this router is too complicated and has too many adjustments.
Re: Plunge router Slipping Question?
How to adjust
Charles Wiggins
>1. Move the lever to the unlocked position, and to a more or less upright position (1/2 way between the motor housing and the stop).
2. You should now be able to push the lever *straight back* and off of the hex nut (be careful - there's a spring that pushes the lever forward).
3. Hold the lever back off the hex nut and rotate the hex nut to the left until you feel it stop.
4. Rotate the lever back to the right a little (toward the stop) and slide it forward back onto the hex nut.
You should now be able to get a more positive lock.
Thanks Charles........
>Turns out to be even easier than you suggested. Just press the lever "down" toward the housing of the router, freeing the hex nut and then rotate the nut one "click" and let the lever spring up and reengage it like a wrench. Easy, but not obvious at first. Thanks again.
Re: Thanks Charles........
Charles Wiggins
>Barry,
It really is that easy, but I do a lot of technical writing for college students who can't follow SIMPLE instructions, so I've gotten used to describing everything in minute detail. That way when they whine I can just say "it's in the instructions."
