Way O.T: Hot tub heater wiring question
David Sparks
>I had a guy install a new natural gas heater for my hot tub. He is a gas guy and not an electrician. The new heater has electronic ignition where my old heater had a thermocouple which required no outside power to operate. I need to run 120 volt power to the new heater for the igniter to work. There are three wires: black, red, and white. I'm not wiring it for 240 volt operation, so I will put a wire nut on the red wire. My question is this: Do I run the ground wire to the metal case of the heater? There is no ground wire in the heater, and there doesn't appear to be a ground screw. Thanks for your help with this.
