Re: PVC for compressed air line runs.!?
Rob Stokes in North Vancouver
>Absolutely positively not!
I've told this story before - but not for a while, so here goes:
I was working in an automotive shop year ago where the owner ran PVC compressed air lines to save a buck. They worked great for a couple of years - no trouble at all. Fast to install, easy to change and we actually had a pretty good sized "web" as it was cost effective to put it together. nothing like having air where you actually need it!
But one day the two of us were working on something and he threw a hissy fit, throwing a basic (9/16 ish) combination wrench on the process. The next thing I know I'm on the ground, my ears are ringing and my face hurts. A quick check of my face with my hand ended up with my hand covered in blood.
After picking myself up and cleaning myself off it wasn't that bad. One of the air line drops must have been hit by the wrench and it had obviously and completely exploded. It was gone, as in absent - as was about 2' of the main line on either side of the "T" fitting. So maybe the wrench hit the "T" - I'm really not sure. My face was absolutely peppered with small cuts, none of them deep, but all of them bleeding a bit. With the exception of a couple of pieces, none of the PVC stuck in the skin and that which did was easily removed by me with some needle-nosed pliers. Not one shard hit my eye lids nor my eyes. Not one. And the ringing in my ears only lasted a short while and then it was over too.
The boss was on the other side of the car - he was completely missed.
After that the PVC came out and was replaced with iron pipe. Never had a problem after that and there was more than one more wrench thrown. I had no lasting effects and the episode has been chalked up to "hmm - learned something".
Hopefully you can convince your co-worker to switch to a more appropriate material for his air lines. If he doesn't - I suggest very strongly that you self-revoke all visitation rights to his shop. I know I'd never go anywhere near it.
Rob
