celing paint?
celing paint?
celing paint?
Ernie Miller
>What is so special about celing paint? and why is it not wise to use just plane white paint? does any one know the real answer? paint store says don't do it.
Re: celing paint?
Re: celing paint?
>Any good flat white paint should work. Personally though, I like the Glidden ceiling paint that goes on pink and dries white. It makes it a lot easier to paint a ceiling.
Re: celing paint?
Re: celing paint?
Lee Ohmart
>I have always found ceiling paint to be a little thicker than wall paint. It also appears to have more suspended solids. I'm not sure what advantage that is. Perhaps less spattering or easier to get a satisfying texture? I also seem to remeber reading somewhere that some brands contain some anti-fungals to prevent that nasty black stuff from growing in areas with high moisture and low air circulation. Personally, I've never had a problem seeing where I'm painting because the old paint has greyed with age. Maybe I should repaint more often? Nawwwww! Good thing the 'ol ball and chain doesn't read this forum.
Re: celing paint?
Yup . . .
steve mackay
>We re-painted the bedroom awhile ago ( wich meant removing the popcorn, Eh Gods ! ) and I FINALLY got an answer to that one from an " Old Guy " at The Borg. Ceiling paint IS thicker and a bit more concentrated so you get more paint sticking to the surface without it dripping or spattering off the roller " AS MUCH ". Is the price trade-off worth it ? From the one time We bought " ceiling paint " ( and will again ) I think so. I never used Kilz before either but, yes, both are worth it.
Re: celing paint?
Dale Lenz
Re: celing paint?
Dale Lenz
>I sold paint some 25 years ago. I was informed ceiling paint is "cheaper paint" as it does not have the scrubbing additives in them, not many folks wash their ceiling. So yes, you can paint the ceiling with WALL paint, but if you are buying the paint, the ceiling paint was cheaper in price years ago and I would assume it still is.
Hope this helps
Re: celing paint?
It's very simple
Michael Dresdner
>Ceiling paint is traditionally paint with higher pigment loading, an industry term that indicates the percentage of pigment to percentage of binder. In other words, there is more pigment in ceiling paint so that it hides better.
Why not do that with wall paint? Quite simple.
The relationship between pigment and binder is what controls the washability of the paint in addition to how well it hides. Once coat of ceiling paint hides very well, but would not wash well. Since most folks don't wash the ceiling as much (or at all) it is considered acceptable for ceiling paint to have a very high pigment loading. I've seen some ceiling paint formulas that exceeded the maximum allowable pigment loading for the resin system. That means the paint would cover very well but would be chalky if you ran your hand over it. Because binder (resin) is usually more expensive than pigment, ceiling paints are often cheaper.
By the way, ceiling paint works quite nicely for doing white wash or pickled finishes where you want an old, chalky look.
Re: celing paint?
Jason Roehl in Lafayette, IN
Unfortunately...
>guys like me who actually use the stuff for a living think most ceiling paint out there is, well, crap. The bottom line is that paint is cheap, even expensive paint. With a good quality, flat white, you'll get as good or better coverage, less overspray/splatter, and a better finish, all while potentially using less paint. The time savings can be significant, too, as a high-solids ceiling paint will feel "sticky" to roll, which requires more time and effort to apply versus one that flows nicely. And, in a higher-quality paint, that doesn't necessarily translate to more splatter. Since I tend to spray ceilings whenever possible (less chance of disrupting any texture), I've run into some "flashing" issues with ceiling paints, where the sheen is not even, nor do they atomize well.
The bottom line in my book is that "ceiling paint" is a gimmick.
In my area, I consider Glidden's Ultra-Hide Flat Latex White (1210-0100) to be the best bang for the buck, but since we get a very good price on Sherwin-Williams' Pro-Mar 200 Flat Latex as well (a little better quality yet), it's pretty much a toss-up. As far as I know, the Ultra-Hide that is sold at the Orange Borg is the same as I get from ICI/Dulux/Glidden.
Some have even debated about who has the "truest white" in a ceiling paint, but the trend I'm seeing in my area is to use a slightly off-white paint on the ceiling anyway. For instance, one we've used quite a bit of is a half-formula of Glidden's "Antique White" (a color commonly used in apartments and tract homes in this area).
Jason (pro painter)
Re: celing paint?
Re: Unfortunately...
Ernie Miller
>I rolled the celing with Kilz 2 we will see how it looks tonight I have alot of that stuff that I bought cheep so if it works or looks good I will let it be and not add any thing else
Some one at a store Orange won't say who said celing paint had somthing in it to reflect light better and not cause shadows? Thanks for all the info
Re: celing paint?
>Nothing cheaper than what you already have. Your source at the Orange Borg is somewhat correct, as it goes back to what Mr. Dresdner was saying about ceiling paints having more solids for better hiding. Part of those solids can be dulling agents such as talc to make the paint "flatter". Flatter paints diffuse light, which helps hide surface imperfections and textures, whereas glossier paints reflect the light, which tends to highlight surface imperfections. That is why flat paint is desirable on a ceiling--you don't want glare and reflections coming off the ceiling, rather, you want any light that hits it to diffuse and even out the ambient lighting.
Jason
Re: celing paint?
Re: celing paint?
Jim Dillon
>Ernie,
Not to belabor this interesting thread, and you have already done your ceiling - so this tip will be worthless for you but might interest others. When we painted the interior of our house not so long ago, we picked a wall color that had a little color in it (to add interest). Our paint dealer (Benjamin Moore) suggested a flatter paint for the ceiling (in keeping with Jason's thoughts) and to add the same tint as in the wall paint, but at a much, much lower concentration to pick up the color in the wall. He also recommended just using the regular B-M line rather than any special ceiling paint. We followed his advice and like the look a lot.
On another note, I was buying paint at the local Borg several days ago and the paintlady (who sounded very knowledgable) told a customer the same thing that Michael said - that one can only load up a paint with so much pigment before problems arise with it washing out.
Jim
