Thin stock in Lunch Box Planer question?
>I have a Dewalt 733 lunch box planer. I want to plane hardwood stock down to 1/8" or slightly less. I tried one piece and it mostly survived, but the planer knocked a plug about an inch in diameter out of the lead end. Did not try it again. (Been resawing walnut for bentwood laminations and sanding them into submission with myPerformax, but its slow.) My thinking is that the knives picked up the lead end. Anyone have a trick for this? How about double stick tape on a caul?
Re: Thin stock in Lunch Box Planer question?
Use a Sled
Dustmaker Mike
>use a sled and put the pieces on it and send it though. I use a sled with a leding edge to hold the piece in it I think the double side tape would give you low spots where it rasied the piece.
P'Max
>Is the tool for this (MO) if your drum is adjusted properly. Keep flipping the pieces after each pass rather than trying to get one side completely sanded. I've taken stock to 1/8" on my JPM-13, but it's a lot more stressful as I keep waiting for WHAM! as the piece gets shreded.
If you want to use the tape/sled situation, plan on a bit of waste at the leading edge which will come out a bit thinner. A 3/4" strip of tape will do, but apply a bit of shellac to the surface for the tape to get a better grip.
Good Luck
Keith Newton
>You might try beveling the lead edge with a block plane to get a little back from the edge before the knives touch.
Also lift the ply higher than normal as the lead edge is getting to the knives. Levering down from under the top infeed roller will make it press down harder while passing under the knives .
Hopfully you have some extra length on your parts. You can not bend wood so the arc runs all of the way to the end. You should always count on a straight at least eight times the thickess from the end of a bend.
Bart Goldberg
Bart Goldberg
>I have the same planer, and have often planed stock to 1/8" thickness. I do believe that it occasionally catches, but its often the exception and not the rule.
Bart
I Use a Sled
>Hello Bart and Barry,
A sled is essential for my tool, also a 733. I can't crank it down easily much below 1/2 inch. With a sled I can achieve thin stock. However, I never tried to get it down to 1/8" inch thick. Normally I stop at 1/4", which satisfies my projects' needs to date. Appreciate your post Bart. I'll try to go slimmer to see how thin I can make it.
George
Jim Dillon
>Barry,
I've had so much luck with this Dewalt 733 table add-on that I keep in installed fulltime. And I've gone down to 3/16 inch several times, but I make sure to keep the piece very flat as it enters the planer. I also try to work up to the thin piece by planing on both sides so the piece stays very flat with no slight curl as thin pieces like to do. The table is nothing more than a piece of MDF with a couple of cleats on each side. I keep it well waxed. It also seems to help minimize snipe. Yes, it does subtract 3/4 inch from the overall planer capacity, but I've never come close to that is the work I've done, and in any case, it only takes seconds to remove.
Jim
Me too, only
Larry Marker in Alabama
>I used a piece of melamine particle board. Nice and slick, and greatly reduces snipe.
Larry
Ron Hildreth, Alta, Iowa
>Jim,
I haven't had to plane anything down to really thin stock, but the plans I recieved for the next clock I want to build from Wildwood designs calls for 64 walnut moldings around all the windows to be milled down to 3/64th". Don't think I'll go that thin with the planer, but the use of a sled should get me down a long way. I'll then use my 22-44 PerformaX to get it to the right thickness.
I noticed on your router table, in your photo, the orange feather boards. Do you like them?
Ron in Iowa
Jim Dillon
>Ron,
Regarding the Bench Dog feather boards, yes I like them and they are easy to use on the router fence as I substituted the miter slot assembly that come with each one for two bolts that fit into a T-slot miter track. However, I also have a pair for working on the table saw where I use the normal miter slot assembly. I find I have to really tighten down hard (I mean serious hard) on the handle that locks the featherboard into the slot. The other handle that locks the featherboard to the assembly works fine.
Gee, as I'm writing this, I just thought that my TS miter slot might be a tad wider than normal. Maybe I could put a strip or two of masking tape on the outside of the feather board locking assembly so I wouldn't have to tighten so hard. Anyway, other than that problem, they are very sturdy and work well. They are a little expensive if I remember right, but I would get them again.
Jim
One more thing...
Jim Dillon
>... if I were to make another one, I would round the outside corners as I have gouged my hip several times as I walk by.
Jim
Solved my problem...
Jim Dillon
>... thanks to you Ron! After my "epiphany" when I was answering you, I went out and measured the Bench Dog miter slot assembly and my TS miter saw. The problem was two-fold: the Bench Dog was actually 1/64 inch less than 3/4 inch and the miter slot was 1/128 inch wider than 3/4 inch. Doesn't sound like much, but for metal tolerances it is a lot. So that is why I had to tighten the expansion bolt so hard to keep the Bench Dog in place. I attached a strip of masking tape to each side of the assembly and it now works just fine. Only took me three years to finally do something about the problem 8-(. Thanks again for your "inspiration".
Jim
