Dovetail jig suggestions
teflon_jones
>Hello, I'm starting up a woodworking shop and I'm looking for a decent quality dovetail jig to help me makes drawers. Any recommendations? I'd like to find something for $100 or less.
Re: Dovetail jig suggestions
>Hmmm - $100 or less? The PC dovetail jig runs about $130-150. It is a reasonable one. The Leigh jig runs a lot more.
You might consider checking out the PC 4210.
Charles Wiggins
>I bought an old style Rockler jig on closeout for around $70, but haven't had a chance to use it yet. Their new "complete" one is around $140 bucks. If you aren't in a hurry, they do put things on sale periodically. Porter Cable's is similar from I what I remember. They both have the limitation of predefined widths - every tail and every pin will be exactly the same, which is fine if you only want dovetails for strength.
The Leigh jigs have the advantage of adjustable widths, so you can vary the width, and thus the look of your tails and pins. If looks are important to you, you probably want to wait and save up for a Leigh ($400). You can always get an inexpensive marking gauge, bevel gauge, a dovetail saw, and chisels, and do them by hand in the meantime.
Also you could check eBay and the Classified listings here and on SawMillCreek.org.
Production?
>If you're doing this commercially and in any kind of volume, I don't think you should be looking at hobbyist jigs that are not designed/built to take the use that you will place on the tool. Spending $100 on something that a weekend warrior uses 2 or 3 times a year to make 8 drawers is not likely to get you a good return on your money. Remember too that since you're not going the "hand-cut" route, you should at least consider outsourcing your DT box construction until you build your business to the point of making it economical to do the DT's "inhouse" with an employee. The time you save for application to other construction details and finishing may outweigh the cost of the ready-mades. I know several 1 & 2-man cabinetmakers in my area who, while doing all their own casework, milling, and finishing, farm out or buy their drawer boxes prefabbed.
Now, if you're targeting the gallery furniture market and plan to give Chico a run for his money, forget the above comments along with the jig idea. |;-}
mm
Dick Coers
>Ain't no such thing. For my favorite all around "pull off the shelf and don't worry that I will have to fiddle with it" I love the Keller. Second choice for speed is the old Porter-Cable Omnijig, Leigh comes in third. I have all three.
If you Hot Rod the Keller a little with "T" tracks and clamps, and use it upside down on the router table, it is a fantastic jig. Once you set the fit you don't have to ever check it unless you drop it. The height of the router bit does not effect the fit, only how much extends out for cleanup. A way underrated jig.
Dave Bair, Eaton Rapids, MI
>I think most of the half-blind jigs work on the same principals. I've had better luck with the ones that come with an aluminum template. But even those can be out of flat so check before you start cutting. My current one ($95)is made by Hartville tool and I've cut about 40 kitchen and bath drawers with it. The results are fine if I do the setup right and the stock is flat. I don't follow the setup instructions exactly; I prefer to center the boards and get a nicer looking drawer side with balanced dovetails. Avoid those that require propriatory bits or guides unless you plan to get one of the more expensive units. Get one that uses a �" shank bit, they last longer and vibrate less.
