Need beam suggestions for bridge
Phil Joines Krum, Tx
>We have a creek through our property that rises about 8� in a heavy rain. The bed is clay and small gravel that washes out easily with the high flow rate during floods.
I need to build a 40� long bridge that will carry me (200 lbs. +/_), the yard tractor (about 300 lbs.) and a trailer with a 55 gal. water tank (about 600 lbs.) from the top of one bank to the other. Because of the soft bottom I think piers would wash out in a fairly short time so I�d like to make it a clear span.
There are a bunch of methods for building beams, horizontally laminated, vertically laminated, plywood I beams, steel, truss and humongo timbers.
Does anyone have experience with something like this? I tried Googeling span tables with no luck.
