ADVERTISE HERE - FREE TRIAL
Motor Wiring Question
Tom Norton
>Thanks to the guys who have helped me out with replies to previous posts about wiring and breaker size.
Next question.
Motor is 230v. It is presently wired with 2 lines , each 115v, coming into the motor. No neutral or ground. There is a 3rd. terminal in side the motor but it is not labeled on the cover as to what it is for. This motor is a 1 directional rotation if that matters.
So where do I attach the neutral and ground?
Re: Motor Wiring Question
>There "should" be a screw attached to the shell or frame of the motor for a ground wire. The gourn does not affectt he running fo the motor, but may/should protect YOU if the current gets onto the shell of the motor.
Dan Donaldson
>Assuming that it runs now, It is connected OK. The ground connects to the frame of the motor, and the neutral does not connect at all. (not required for 220 volt operation>)
Search?
>I have a Century motor dated 1914 and found a little information on it on the internet. Since your's is 1966 perhaps there is moer info. If you serach goole you might be able to find a wiring diagram or something for it.
Happy Woodworking!
Gene Gauss
>To expand on what Barry and Dan have written, if you can't find a dedicated ground connection (often a green colored screw), connect the ground wire under any convenient nut or screw head, and make sure the ground wire eventually connects to the ground bus in your service panel (perhaps through a connection in the housing that contains the on-off switch) This ensures that if there is an insulation failure anywhere on the machine, the frame of the machine will not go above ground potential to shock you, and the source breaker will trip). Gene Gauss
