"Wooden Flowers"
"Wooden Flowers"
"Wooden Flowers"
Howard
>A friend wants to make a wooden floral display for here sisters grave. She would like to make and paint 8 wooden flowers 30 inches high and set them in concrete. Can anyone give me advice as to what would be the most rot resistant wood to use?
My first guess would be �sinker cypress� that has been reclaimed from old logs retrieved from sunken lumber barges.
Also any ideas regarding preventing the wood embedded in te concrete from rotting?
Thanks
Howard
Re: "Wooden Flowers"
Hard to tell, Howard
>There are a lot of rot resistant woods and cypress in general is one of them. (You don't have to seek out sinker cypress. The appeal of those variations is that they were mostly first growth logs, so they are very clear and close grained, and they have usually absorbed some interesting color from their time in the swamp.)
But there are other considerations, I would think. How will these flowers be made? If they will be carved, then softness and workability will be factors. Cypress will be a good choice in this case. Other rot-resistant woods (e.g., ipe, teak, lignum vitae) are harder and possibly more durable, but they will be a lot harder to carve.
How thick will the cross sections of the petals and other parts be? Thin cross sections of different woods shrink, dry and crack differently, especially when left in full sunlight. Your friend may find that cypress grain tends to flake when it dries. This may or may not be objectionable.
Regarding the concrete base situation, I think all woods rot eventually when set in concrete. I've had good luck by standing posts in a bucket of creosote before setting them in the 'crete. You might want to look into using a wood preservative, regardless of which species you decide on.
Hope some of this is helpful.
Ellis Walentine, Host
Keith Newton
>I don't know where you are, and what is available to you, but I would also avoid using dry wood, as in bought lumber. If you are where you can find some of the best rot resistant woods to your area, the carving process is sooooo much easier when carving green wood.
Also, without knowing more about the details of how large the wood parts, and or proportions of the concrete, the absorbing wood can easily expand and crack green concrete.
Beyond this, setting wood into concrete especially if it is in a flat surface facing up, will be about the harshest environment that you can put wood into. Even the best woods will have a hard time there.
Some of the best woods in my area are Osage, or Bois-D-Arc, Black Locust, Catalpa, Eastern Red-cedar.
Doug Turner
>Black locust is used for fence post due to rot resistance and has pronounced grain.
