Deft
Randy Johnson Connersville, IN
>I recently bought some Deft lacquer to try as a finish on bowls.
The directions say not to thin it and they also mention light coats. With the can I have, applying a "light" coat is impossible. It's like brushing on honey. Actually the first coat isn't all that bad. It isn't like shellac, but it does more or less flow on. After the first coat, the brush drags. Even 24 hours after the previous application it acts like I would expect if I was trying to apply it too soon between coats. Because of the drag I'm having to put way too much on to not have areas that are missed.
The directions also say it can't be sprayed or I would try the hvlp.
I've tried different brushes thinking that might help. It didn't.
Did I luck out and just buy a can of the stuff that for whatever reason is too thick? (doubtful) Or, is there something about applying this product that I am simply missing? (likely)
I'm ready to give the sawdust/shavings pile a real nice finish and go back to slower but easier methods like shellac and oil.
