THE WOODRAT IS BACK!
wood moving with humidity
Doug Bradshaw
>I have some walnut glued up. I want to put a boarder around it like a picture frame. I don't want the corners to open up because of swelling of the center boards. How should I go about fastening the boarder, or allowing for the eventual movment.
Thanks
Re: wood moving with humidity
John Parker
>There is nothing ,aside from a constant temperature and humidity level, that will stop solid wood from changing dimension. If you want a picture frame type surround you will have to use frame and panel construction or use a ply type center to stabilize the core.
