unknown drill bits
tim_in_michigan
>Can someone tell me what bits like these would be used for?
unknown drill bits
tim_in_michigan
Re: unknown drill bits
John D. Luke
>Drilling holes.
Rick W
>The top one probably goes in a boring machine, perhaps a horizontal borer.
The bottom one is a regular drill bit that has a Morse taper shank that fits directly in a drill press or lathe spindle.
Rick W
Ken Oakley-Sunny St. Cloud, Fla,
>The bottom one looks very much likes ones I have used on vertical milling machines such as a Bridgeport.
Al Stokka - Cambridge, Iowa
>Tim,
Drills similar to the top example (threaded shank bit) are common in the aircraft (building) industry. They are typically mounted in a right-angle drill for use in close quarters. The threaded shank saves the length of a chuck.
The point on your bit, though, appears to be configured like an auger-type bit so is likely made for use in wood.
Google threaded shank bits and you'll see examples of the bits and also the right angle attachments.
Al
