Penn State Industries dust collector *LINK*
Dan Mitchell
>I'm considering this dust collector & am wondering if anyone has one or another by this company. $320 delivered seems like a pretty good price for a 1 micron, 2hp collector. Opinions?
TIA
Dan Mitchell
TIA
I should add it comes w/50' of hose! NM
Dan Mitchell
If it's like the hose I got
Curt Harms
>it's not worth unpacking. Basically dryer duct that won't stay round even when there's not a vacuum in it. I have an older version of the "2 h.p." dust collector with a Wynn spun bonded poly cartridge filter on it that works pretty good. I got 2 clear 6" hoses, one from Amazon (Jet branded) and one from Wynn. They both work fine, the Jet one might be a little smoother inside.
Curt
Re: Penn State Industries dust collector
Dennis Yoder
>I have one hooked up to a distribution system. It works fine but the bags clog up fast if you are sanding a lot, but that is what a 1 micron bag is supposed to do. I just beat on it and blow air from the outside and its good to go. The hose that come with mine is more than adequate. Dennis Y
Dean Lapinel
>Had mine quite a while. Absolutely no problems with it.
Dan Mitchell
>Thanks for the replies. Seems like a pretty good deal, I think I'll go for it. I'm still setting up my shop, but even just from the process of making an outfeed table for my TS, it's become abundantly clear I need something more than my shop vac!
Thanks Dean!
Dan Mitchell
Jim DeLaney, Austintown, Ohio
>I've got one - had it for about two years, and like it a lot. I upgraded to it from a DC1B that I'd had for ten years. Mine has the cartridge filter, but the mechanicals are the same as the one you're looking at.
Forget about the free 50' of hose. It's just black dryer vent hose - pretty useless, except for very short connections.
I have my shop plumbed with 4" PVC, and only use flex hose for the drops.
Re: Poor quality hose.. *LINK*
>as others have said - pretty much worthless. The DC would probably work quite nicely. I was quite pleased with this hose (see link). The price was fairly reasonable - and I was able to pick it up while purchasing something else.
DC Hose
>Dan, we go on and on about DC's here and that's a good thing.
I have not seen Bob Dodge post in a while but he has help may of us with our systems. One thing he suggested was to remove the restrictor plate from the throat of the inlet on the DC. Mine had a six inch inlet, but right inside of it was a plate with a four inch hole in it. If I recall it was designed to provide "some" restriction and prevent the possibility of the unit running for a long time without some pressure on it. (Probably not stated well, but you get the idea). With most of us, the system has plenty of back pressure, restraints on air flow or whatever. On the inlet side there is at least some pipe and probably some fittings and hose and on the outlet side there is the bag and it gets caked with dust.
After a couple of years I noticed that part of the magic of mine seemed to have gone away. Not sure if I had become jaded or if indeed it had deteriorated. That's when I removed the restrictor plate. (A little help, mot much) I added brushes to the underside of my table insert on my TS. (They helped, but not much loss there anyway, so catching half of a small amount still leaves a little
escaping.) I tried increasing the hose on the TS from four inch to five inch. (Nothing, The inlet on the saw was so ell enclosed around the blade that the air low probably did not increase at all.)
Is your TS a Contractor's Saw or does it have an enclosed cabinet? If its a Contractor's Saw I just saw a neat tip in Wood magazine. Use a flue flashing (or pipe collar of roof jack) for a metal flue as a "funnel". Turn it upside down and insert it between the stand and the saw and bolt it in with the bolts that how the saw. Buy one that fits a four inch flue and you can modify the end of it to accept four inch hose or pipe. You can close off some of the back of the saw. Some people have used scraps of plywood stuck to the saw with magnets so that you can take them off momentarily when you tilt the saw.
The best thing I did to restore the performance of my DC? Normally, when I empty the bag I shake the filter bag and try to let the cake fall into the trash bag. Seems to help. Finally, I took the bag off and turned it inside out and shook it out. Warning, this is something you want to do on a breezy day with your back to the wind, holding your breath and under an assumed name. We a talking dust explosion here. It was so surprising, I did not do it as thoroughly as I should have. It made an amazing difference. Definitely do it outdoors but, don't do it up wind of your car or your neighbor's car when there is dew on the cars. You will hear from them. This is a messy process and I am glad my DC is outside in a shed.
Nick Tuzzolino
>Have one for about five years. No problems.
Dan Mitchell
>Thanks for the informative responses. I'm going to order one today. Seems like a good deal & even if the hose is crap, it's probably good enough to get me up & running while I work out a permanent solution. Barry my saw is a PM2000, so it does have an enclosed base.
Dan
Re: Been doing the math for pipe in my new system *LINK*
Peter Gregory
>I have been doing the math for collection needs for my equipment and how big the pipe needs to be. It is interesting how much is lost in a 50' flex hose vs. any kind of pipe. If I was going to have a system like this and move it from machine to machine, I would be looking at using a 10' hose if I could. 50' flex hose isn't going to work well, no matter what the quality of the plastic. If you had a 3hp cyclone, it wouldn't work well down a 4", 50' flex hose (I have done the math on that one).
They recommend "Woodshop Dust Control," by Sandor Nagyszalanczy on the site in the link. I already had my library's copy and it is a good book.
Good luck.
http://www.airhand.com/designing.asp
Good use for the *free* hose
GaryMc
>I have the DC2000 with the cannister filter, works very well with about 50 feet of branched 4" ductwork. BTW, if you buy the cannister model you also get the double bags, plus 10 heavy duty waste bags.
Lot here about the free 50' hose, which I only use for short (<5 foot) connections to semi-mobile machines (it is more flexible than most), but yesterday there was a very desirable use for it. I was in the middle of jointing several boards when I realized that the blast gate was not open. Opened it up and heard a wad of shavings suddenly exit the machine and *THWOOP* through the piping, resulting in a blockage. Uh-Oh, overhead PVC piping, taped joints all, so figured it would be a major headache to find and clear it. I used the 50-footer to run from the DC to various ports, noting which branches, etc., were open or still blocked. Result - pinpointed where the problem was (fairly near the DC) and only needed to separate one joint to clear it. That hose paid for itself in a single use.
