OT: Dishwasher leaking through door
David Hay @ Denver
>I'm hoping that the broad range of experience here can help me with a problem our dishwasher has developed. Yesterday, the dishwasher started leaking through the bottom of the door during the normal wash/rinse cycle. I pulled it out and checked the drain hose and underside of the machine to make sure it's draining properly, and it appears to be doing so. In fact, if we hit 'Cancel' it does drain.
Any ideas? I'm not entirely sure how the door is supposed to seal at the bottom, so I suppose that's one possibility. Could it have developed a problem where the water won't shut off and it's overfilling? Any other places I might look for advice?
Thanks!
David
Re: OT: Dishwasher leaking through door
John Pappas
>Dave, This may be a real stretch, but about 30 years ago (so I don't remember all the details) we had a problem with a similar leak. It turned out to be that the rotating arm (whatever that is called) had developed a hole in the underside as a result of heat from the heating element. Somehow that affected the action within the cabinet such that it leaked. Replaced the rotating arm and the problem was fixed. By the way, I didn't figure this out myself. A person in an appliance parts store told me to check the arm, as this was not an uncommon problem.
Dan Mitchell
>The ones I've seen don't actually seal at the bottom, the door is made in such a way that the water drains back into the tub. Make sure the machine is level in all planes. If you take the lower access panel & outside of the door off & run the machine, you may be able to see exactly what's going on.
Dan
>Does the unit leak only when its in the wash cycle? If so, it may have developed a crack or split in the door gasket. If the unit is a few years old the gasket may have dried out and split. You can repalce it, but it may not be worth it. Sort of pull it away from the door or cabinet gently and see if it is not held on by a whole row of screws.
If it fills and leaks before the wash cycle starts, then it may be the limit switch that shuts off the solenoid when the unit is full. You should be able to tell by letting it fill and then opening the door before the wash cycle starts. Check the water level against the height of the lip or sill across the front. The water should be an inch or at least a half inch below that level. In name dishwashers the shutoff switch is a "Cup" turned upside down that floats up when the water level is reached. Be sure something in the load is not blocking it. Then take it apart and see if it is restricted by some sort of crud. My neighbor had this happen. He cleaned it thoroughly and it went back to work.
Its also possible something about the way you loaded it deflected water in some unusual way and caused it to leak.
Tates in Chesterfield, VA
>Google "Dishwasher Repair" and follow the troubleshoot paths. I have a 3 year old Kitchen Aid dishwasher that had a water leak and found the parts online at a big discount.
Dave Huber
>I had a similar experience.
My trouble was that some gunk had formed on the gasket along the bottom seal. It was hard to see without standing on your head to look at the bottom of the door.
Once I found it, I cleaned it and have had no trouble since.
Good Luck.
Agree - check for gunk and food
M. McNamee
>Had the same problem, some food had gotten down there unseen and caused the leak. A good cleaning took care of the problem.
Lee Ohmart
>We had an older dishwasher that developed this problem. When we removed some panels and opened up the door, what greeted us was a corroded nighmare. It was a wonder it was still working. Long story short, we replaced it with a newer, quieter and more energy efficient model. It pays to do a little disassembly to see what you're up against.
Re: OT: Dishwasher leaking SOLVED!
David Hay @ Denver
>Thanks for all the great advice. It turns out that a couple of the jets of the upper rack sprayer were clogged with junk. They were probably spraying into the vent on the door. After cleaning them out (and giving the vent a good cleaning) and cleaning off the gasket as well, the leak seems to have gone away.
David
ditto: same experience
Bill Schreiber, Litchfield, NH
>I recently had a sudden leak start up like you did. Took a damp rag and cleaned all the way around the gasket and fixed the problem.
Worth a try anyways.
Good luck,
Bill
