>A friend has a dresser on which she placed a potted plant. The dish under it leaked and water absorbed under the finish. I know this has been covered before, I just can't seem to find it. What is the best way to remove that haze spot? The dresser was mfg. in the 50's, and i believe the finish is varnish. I don't claim to know how to repair damaged furniture, so any advise will be greatly accepted.
Dampen a cloth with denatured alcohol and wipe the area once or twice with it. The white marks will come out immediately. Repeat if necessary to get them all the way out. The cloth should be damp, but not wet, which means "about as wet as a healthy dog's nose." This method is also safe for shellac, due to the limited amount of alcohol being used.
>By the way, if this came from a factory in that time period, its finish is almost certainly nitrocellulose lacquer. The solution given with the swipes of alcohol is generally the best.
