Re: resanding hardwood floors
Mike Fitterling
>Hi, Paul. What are you trying to do? Do you just need to refinish to get rid of surface scratches or do you need to remove all finish and start from scratch?
For removing all finish you can't beat a drum sander, btu it takes some finesse to use it properly and not have dig in marks. But in a narrow hall that on't be an option.
If you just want to freshen up the floor, you can just use a random orbiting sander. It is not usually necessary to remove all the finish if the floor just has surface scratches. I've even used a vibrating pad sander for that followed by a single coat of poly.
If you need to remove the finish, that is going to be tough. You could probably use a rented edge sander and then followup with a ROS and/or pad sander.
It also will matter what the finish is that you are removing. If it is poly it will sand out pretty easily; if it is an old house with shellacked floors, you will go through a lot of sandpaper because of laoding. In that case you may want to chemically strip the floor first.
Good luck,
Mike
