Routing with a template
Gary Evans Tallassee, TN
>I have a 10 year-old 3HP (yeah,right) Ryobi plunge router that I want to use to form M&T joints to attach the legs on some rustic benches that I'm going to build.
I have a number of slabs of maple 8/4 and 12/4 thick and I thought I would make the legs out of the same stock. Each of the two legs will be nearly as wide as the top. I'll make some sort of cutout in the bottom of each leg so that the bench sits on four feet.
I thought I might join the legs to the slab with M&T joints, routing the mortise and tenon using a template guided bushing. The mortise seems a no brainer since I can sit the template and router right on the bottom of the slab. Cutting the tenon on the end of the leg seems a bit trickier, but I thought I might make the template in the form of a table that would hold the leg securely in place while I run the router around the edges of the endgrain. I am wondering what type bit would be best to use and whether there might be an issue of getting a smooth surface on the shoulder of the tenon by cutting across the end grain the way I'm thinking of doing. I'm thinking of maybe a 1/4" deep x 3/4" tall cut all the way round.
I'm looking for a method that will give me easily repeatable results with a minimum of set-up time. I plan to make a number of these benches. I know I could rout the tenon by cutting each face separately on my router table, but then the leg has to be turned four times to make all the cuts.
Also, does anyone know whether the Ryobi will accept standard bushings? I've never tried this type of routing before, hence all the questions.
Thanks,
Gary
Re: Routing with a template
Bill Roland (Mt Juliet,TN)
>I have that router set up for my router table with a modified after market base plate. I looked for the manual, but didn't find it and could not find the original base without a lot of digging. I am still recovering from Cervical surgery and can't do a lot of lifting. You should be able to find a universal base, mount it on your router and use the guide with it.
