Old pipefitter's trick
Charles Wiggins
>If you're doing production work, I think your jig has a lot of promise, and there's been some great suggestions for improvements. However, if this is only an occasional problem for you, you may want to consider a low-tech solution.
If your cylinder (dowel) is straight and true, you can take a flexible straight edge (the edge of an index card, for example) and wrap it around the cylinder so it laps back over itself, aligning the straight edge perfectly to itself, and you will have a perfectly perpendicular line, that goes all the way around, to scribe against. I used to use a piece of 1/16" spring steel to mark large diameter pipe.
