>I snagged an old Delta contrators saw 34-444 ($200 with 52" beise fence + original fence) but it needs some repairs. Looking at the arbor and going by the exploded Delta parts diagram I have it looks like what I have is a broken bearing closure nut, looks like some sort of retainer on the pully side of the arbor.
Is the best way to get at this by unbolting the whole tilt/raise/lower /truion assembly from the trunion bracket?
How much force is the arbor pressed in with? Do I need to get a press or can I tap it out with a hammer (while protecting the thread of the shaft of course)
Is the flange on the side of the blade between it and the bearing part of the arbor, i.e. stationary and isn't removed from the arbor? Looks like it and doesn't have a part number separate from the "arbor assembly"
Is there anywhere but Delta to get parts for the saw?
Where might I find wrenches for taking the blade on and off?
As my good friend Dave Arbuckle posits, the thing that's shipped with the saw for blade removal is not a wrench—it's a pattern. My Unisaw shipped with a 7/8" pattern. When you verify what size your arbor nut is for sure, run down to your nearest wrench purveying emporium and pick up a shiny new combination wrench in that size and keep it in the channel on top of your Bies for easy access.
Incidentally, you only need the one. The arbor nut only needs to be finger tight when you replace the blade, although you can snug it a tad more with your new wrench. To remove the nut, which, with use, will have become quite tight (and the reason why “finger tight” is good enough when you install it), just stick a scrap of wood in a gullet in your blade to hold it while pulling the wrench. Remember, too, that if you have a right-tilt saw, your arbor is probably a left-hand thread, so “righty-tighty” won't apply.
>It can get confusing whether you have a right or left hand thread on the saw (right or left tilt different). The way to remember is that to loosen, always move the top of the wrench to the front of the saw, and to tighten, to the back. This will always work regardless of the type of saw you have.
You shouldn't have to remove the whole assembley to repace the bearing closure nut.
No need to take the arbor out for the initial part you mentioned in the first place.
The saw flange is part of the arbor.
You can get it from other sources but ultimately it comes from Delta and most other sources will cost more.
A standard wrench will work fine along with a piece of wood to wedge between the teeth. This a standard practice on most saws for decades. Putting the blade back on doesn't require much tension as the arbor nut is self tightening due to the rotation direction.
I've repaired enough Delta saws over the years when I worked for a dealer.
