>Working on a guitar stand for my brother. Resawed two walnut boards into laminations about an 1/8" thick and glued them back together in sort of a lazy S. I will try to post again when I make some more headway.
>I just got a decent blade for my BS, but haven't done any resawing. I do remember an article somewhere about how to set the saw to adjust for blade run out, but can't remember. Is there anything special to do when resawing. I'm mostly a turner and not that familiar with flat work. TIA.
>Looks like a yellow-glue bottle on the TS to the left.
Barry, I would suggest that you leave that in the clamps for several days before you remove the clamps, given that glue choice. But then again, I don't know how hard or easy it was to get your stack of plys to make that bend.
>I removed the lamination's and they are about a 1/10". Seven plays totaled just under 3/4"
I was in a hurry and wanted to do this on the cheap so I glued the center third which is straight with Original Titebond ($3.40). The ends where it curves I used Titebond lll ($7.60). Hows that for cheap? Not sure lll is any better than Original, but it claims to have better open time and I wanted to get 27 clamps on and had to do it by myself.
I know there are better glues for this, but I did not have any and grabbed what I could at the Borg. Thanks for the advice, but too late, The clamps came off this morning. I left it in the clamps
over night". Apparnetly something mystical happens during the darkness, because things work better if you leave them over night.
This morning I took off the clamps, cleaned up the edges, ripped the bottom down to two inches by taking a two inch piece off each side. I rotated those pieces ninety degrees and they are the flared legs. They are glued on long grain to long grain. A little more sanding and finishing and this baby is done.
And here's what it looks like now. I will try to co a better picture later
>I mentioned to a friend I was building this for my brother and now they want one. I showed it to my son and his girl friend and now she wants one or two for her brother and step father. Of course these people want them for free or very cheap. Wonder if it would sell for enough to make it worth my time?
I think, if I make more I will replace most or all of the clamps with All Thread rods and shackles.
